Help installing a Starter, B18b
Old Jul 27, 2011 | 09:31 AM
NayborhoodJohnny's Avatar
Default Help installing a Starter, B18b
i have a 1992 integra ls coupe w/ b18b engine.
I need help installing my new starter.
can anyone help me out?
Old Jul 27, 2011 | 10:17 AM
osbunjosh's Avatar
Default Re: Help installing a Starter, B18b
standing in front of the car looking at the motor of the left side of the block you will see it. There are two bolts: one on top and one on the bottom. There is also a bolt of top of the starter itself the hold the battery cable. Disconnect your battery. Unscrew the starter battery bolt. Then the other two bolts. Slide it out. Install new one in opposite order.
Old Jul 27, 2011 | 11:07 AM
thanks!!!
Old Jul 27, 2011 | 11:08 AM
do you know what size each bolt is?
Old Jul 27, 2011 | 11:37 AM
osbunjosh's Avatar
Sorry no i do not. But make sure to disconnect the battery. And you will have no problems getting your hand in there with a ratchet and figure out what size it is
Old Jul 27, 2011 | 09:09 PM
JOE_DC4ever's Avatar
Probably want to take off intake arm for room and the bolts are 14mm (should be) the one on top is alot shorter than the one on the bottom by the way..
Hopefully you have it all buttoned up by now though
Old Jul 27, 2011 | 10:08 PM
osbunjosh's Avatar
Thanks for the bolt size.
sik_sol
Jul 7, 2006 08:13 AM
B16A3Civic*Eg
Apr 25, 2006 01:57 PM
95GSRTT
Oct 4, 2004 03:45 PM
johnsona
Oct 19, 2003 09:36 PM
