HELP: Installed new header
Old May 23, 2004 | 09:41 AM
variable_x's Avatar
Default HELP: Installed new header
Ok, I just got a new DC Sports Header installed on my ls. Now there is a slight rattle coming from the catalytic converter and the car also sounds like there is an exhaust leak. Is the car suppose to sound like that with a header? The nuts on the supporting bracket for the secondary pipe broke off, so I just redrilled another hole on it. So now it has only 1 bolt holding it instead of 2. Could that be what's causing the rattle from the catalytic converer? Any opinons will be greatly appreciated. Thanks.
Old May 23, 2004 | 09:55 AM
andrew dc's Avatar
Default Re: HELP: Installed new header (variable_x)
the rattle can be from anywhere... probably the cat hitting a heat sheild. did you run the car while it was up on jack stands and listen for the rattle.
As for the exhaust leak, it can be from anything... the donut on the header, like you said, it could also be that the header is held to the cat with one bolt. I used a long grade 10 bold and washer instead of the spring loaded one for one side.
HTH
Old May 23, 2004 | 10:49 AM
variable_x's Avatar
Default Re: HELP: Installed new header (andrew ef)
The rattle is not constant. It only occurs when I am starting the car from idle in first gear ( moving the car from a stand still ). Also there are 2 spring loaded bolts connecting the cat with the header. I was refering to the mounting bracket under the engine where only one bolt is holding the header in place.
Old May 23, 2004 | 11:06 AM
ingrate's Avatar
25 Year Member
i doubt it. i just stuck the studs through the bracket w/o nuts to secure it and i didn't have any rattles.. did you replace the donut gasket?
Old May 23, 2004 | 04:09 PM
variable_x's Avatar
Default Re: HELP: Installed new header (ingrate)
What's the donut gasket? Am I missing something here? The header came with 2 round gaskets to put between the primary and secondary pipes. I put those in. Is there another gasket that I should be concerned with?
Old May 23, 2004 | 06:31 PM
variable_x's Avatar
OK, it seems like that I was missing the donut gasket. Thanks guys. After putting that on, the exhaust leak is no longer there and the majority of the rattle is gone; however, there still seems to be a slight rattle when I am accelerating at around 1500rpm coming from the cat. I wonder if it's because I only have 1 bolt between the 2nd header pipe and the supporting bracket.
Old May 25, 2004 | 10:13 AM
variable_x's Avatar
hmmm... anyone experiencing the rattle at 1500 rpm with a DC sport header?
Rzoops
19
Jul 19, 2005 09:02 PM
Truecure
Apr 14, 2005 11:09 AM
rewhipple
Apr 6, 2005 09:22 AM
fOmaNPu
Dec 25, 2003 02:28 PM
drifter
Mar 6, 2002 06:08 PM
