HELP! ignition problems!
Old Jan 18, 2003 | 02:46 PM
roman420's Avatar
Default HELP! ignition problems!
Okay so about 3 days ago my 1991 Integra LS automatic (B18A1) would not start. replaced cap/rotor/ignition coil and it fired right up. idle sounds great, but there is still a remaining problem. tachometer sweeps erattically during acceleration and is inaccurate, misfire/spark knock very apparent, tried setting timing and resetting ECU, kept the car running instead of occasionally just dying for no apparent reason, but a power loss and sputtering was still very apparent. removed dis, cranked engine to TDC, re-mounted distributor, started right up but no help with the sputtering/ping/knock either. doesn't seem to just die anymore but performance is terrible regardless of timing setting. my current guess is either igniter or ???????
PLEASE HELP! i can provide any info that may be needed for possible diagnosis, but i cannot afford to take this car to a shop, and it is my daily driver.
Old Jan 18, 2003 | 05:50 PM
roman420's Avatar
Default Re: HELP! ignition problems! (roman420)
Fixed! problem was a loose wire on the igniter chip. if anyone has a similar problem be sure to check those wires first!
-drew
Wil Beck
Mar 18, 2017 08:34 AM
T:rex
Jun 11, 2010 09:28 AM
Throwback23
Mar 29, 2009 07:26 PM
rotascircuit
Mar 22, 2008 11:29 PM
