help i am throwing cel code 23
I did a search didnt find anything for cel code 23 which i belive is a knock sensor. I am runing a ls/vetc so i dont have a knock sensor. I was told there was a way to ground it out any help would be greatly appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorteg_96 »</TD></TR><TR><TD CLASS="quote">I did a search didnt find anything for cel code 23 which i belive is a knock sensor. I am runing a ls/vetc so i dont have a knock sensor. I was told there was a way to ground it out any help would be greatly appreciated. </TD></TR></TABLE>
That grounding **** doesn't work... Tried it already... Only way to remove the code is to install a knock sensor into your alternator bracket, or get some kinda fuel management i.e. Hondata and disable it...
what ecu are you running ?
Get yourself a P28 and your problem will be solved. Other wise, install a knock sensor, or get an engine management that will allow you to disable it
what ECU is the P61 from ? Is that the 92-93 GS-R ECU ?
I think it is....
But yeah, if you can, get a hola of a P28 ECU. Since it appears you are OBDI, keep it to an OBDI ECU also. I am pretty darn sure that will solve your problem.
If you know anyone that has one, you can always try it out then before you bought one.
I think it is....
terplaygroun_dc2
Oct 23, 2008 09:38 AM
oranginal
Jul 6, 2006 02:17 PM
