help help help!
Old Jan 30, 2006 | 09:50 AM
b20integrapower's Avatar
Default help help help!
...im doin a valve adjustment on my b20b...do i put the feeler in from the top...like over the jamnut and inbetween the lobe and lifter? or do i go from the side? just need a quick answer
Old Jan 30, 2006 | 09:54 AM
Danza's Avatar
Default Re: help help help! (b20integrapower)
I've never done it myself, hopefully this pic from c speed will help you:
Old Jan 30, 2006 | 11:49 AM
Default Re: help help help! (Danza)
thats different...this motor isnt vtec...the jamnut is on the same side as where i would adjust it...in that pic they are on opposite sides...i need this fora b20b
Old Jan 30, 2006 | 01:36 PM
Sam92Teg's Avatar
I have an RS which has the same head design as yours, and you just put the feeler gauge inbetween the cam lobe and rocker arm when the piston is at TDC. I don't really see what your question is, it was pretty self evident when I did mine.
Old Jan 30, 2006 | 05:55 PM
Default Re: help help help! (Sam92Teg)
from the direct top..by that i mean...over the jam nut and between the lobe and lifter...or go in from the side with the gauge...if i use straight gauges it doesnt seem practical to go from the direct top...i got angled gauges today..so ill try it
CHAPY
Apr 13, 2005 09:53 AM
