help with ground control...front and back install ??????
Old Oct 1, 2002 | 04:16 PM
NoNOSgsr!'s Avatar
Default help with ground control...front and back install ??????
simple question yet not so simple for me.
got a set of used ground controls for a G2 but i'm not sure which one is for the front or rear..
22/98 GC 180.64.44..........
19/98 GC 200.64.58..........
info will be appreciated..
TIA
NoNOS
Old Oct 1, 2002 | 05:20 PM
TimoneX's Avatar
New User
Default Re: help with ground control...front and back install ?????? (NoNOSdc2)
The shorter springs go in the back.
Old Oct 2, 2002 | 09:52 AM
NoNOSgsr!'s Avatar
thanks for the reply.. how bout the thing where it sits on...does the short ones go in the front or the back..
again thanks for the reply.
NoNOS
Old Oct 2, 2002 | 11:28 AM
TimoneX's Avatar
New User
You mean the sleeves and perches? I don't recall. Didn't you get any instructions? You have to alter the stock dust covers, bump stops, & install the proper O-rings. If you're not certain what you're doing contact Ground Control &/or have someone else do the work. Suspension work is really not something to muddle your way through. If you still can't get it, lemme know. I installed my own, but it's been 1 1/2 or so, and I've had no reason to disassemble them.
Old Oct 2, 2002 | 03:44 PM
NoNOSgsr!'s Avatar
Default Re: help with ground control...front and back install ?????? (TimoneX)
i have lots of suspension experience but never installed ground control before. the ground control i got are use and had no idea which one goes with which.
anyone got ground control's phone #
NoNOS
Old Oct 2, 2002 | 04:04 PM
IN VTEC's Avatar
On a friend's Accord, we had to install the shorter sleeves on teh front and the taller ones in the back.
First time around, we put the taller sleeves on the front and his ride ended up all jacked up in the front. Two handed fisting permitted in his fenderwell.
Old Oct 2, 2002 | 04:07 PM
TimoneX's Avatar
New User
Default Re: help with ground control...front and back install ?????? (IN VTEC)
(530) 677-8600
http://www.ground-control.com/
Perhaps they can fax you the instructions. Good luck.
adriang2
Suspension & Brakes
Nov 10, 2010 05:42 AM
eklum
Suspension & Brakes
Mar 7, 2006 09:19 AM
tub_sephiroth
Jul 10, 2002 04:08 AM
Brewer
Feb 7, 2002 07:37 PM
PureTeg420
Oct 14, 2001 03:42 PM
