help with fuel filter...
Old Dec 22, 2001 | 11:33 PM
bocian's Avatar
Default help with fuel filter...
time for me to change my fuel filter
which is the best way to go???
i saw an AEM for 90 bucks but come on....
is original honda equipment best?
any and all imput is appreciated
TIA
BTW-> how hard is it to change it? any special tips or pointers to remember?
Old Dec 22, 2001 | 11:40 PM
Jesse H's Avatar
Default Re: help with fuel filter... (bocian)
The banjo bolt may be a little problem, but other than that it's easy as pie. Make sure you releive the fuel pressure first. OEM is fine.
Old Dec 23, 2001 | 10:50 AM
speedymon's Avatar
Default Re: help with fuel filter... (Jesse H)
90 bucks!!! Does it suck your d!ck too? I'd stick with OEM. Sounds like AEM trying to make a buck. That is unless you putting down mad powa y0!
Old Dec 23, 2001 | 08:51 PM
bocian's Avatar
Default Re: help with fuel filter... (speedymon)
hehehe i wish it did,
how much does the OEM filter go for?
Old Dec 23, 2001 | 08:52 PM
bocian's Avatar
im a novice
how do u relieve the the fuel pressure???
Old Dec 24, 2001 | 05:45 AM
JCushing's Avatar
just pull one of the injectors outa the fuel rail hehehe
Old Dec 24, 2001 | 09:44 AM
Cow's Avatar
Cow
Default Re: help with fuel filter... (JCushing)
Won't opening the gas cap relieve fuel pressure?
Old Dec 24, 2001 | 02:57 PM
Erik_Pb_Foot's Avatar
New User
Default Re: help with fuel filter... (Cow)
Couldn't you just undo the banjo bolt slowly with a rag covering it to keep gas from spraying everywhere? I've never done it, just thinking it might be easier if you could eliminate having to remove the injector.
Old Dec 24, 2001 | 03:24 PM
maxxdout's Avatar
Default Re: help with fuel filter... (Pb_Foot)
ok, you guys are putting way to much effort into this. Let the car sit for alittle while so that you dont burn yourself while working in there. Second of all, get OEM cause it doesnt matter. Just so long as your fuel is new and clean then its doing its job. As far as pressure relief, just remove gas cap, and undo the bolt slowly, have some rags under it and be ready for a little spills, not too bad a few drippies. Fairly easy. The service bolt on the very top doesnt need to come off just the banjo bolt. And be sure not to put pressure on the lines themselves because they are hardlines and could break. Good luck.
Old Dec 24, 2001 | 04:05 PM
Max GSR's Avatar
im a novice
Just unscrew the gas cap. Ever hear the "whooosh" sound when you unscrew it to fill up an empty tank??
Old Dec 25, 2001 | 01:04 AM
bocian's Avatar
Default Re: help with fuel filter... (Max GSR)
thanks, im stupider than i thought hehe
like i said "novice"
thanks again for all the info guys
Old Dec 25, 2001 | 11:45 AM
B18C-EJ1
Guest
Posts: n/a
AEM fuel filter - Waste of money
OEM fuel filter - $25 (only needs to be changed every 100k miles)
Old Dec 30, 2001 | 07:07 AM
97accordex's Avatar
Releive fuel line pressure by loosening a service bolt on the fuel rail if your model is equipped with on.e I have a 97 accord F22B1 and it has the service bolt.
Loosening the banjo bolt on the fuel filter will do the same thing,,,,,,,, make sure you open the gas cap first,,,,, then get some rags and get ready for some squirtin gas.
Old Jan 29, 2002 | 11:03 AM
Phat Corolla's Avatar
New User
Default Re: help with fuel filter... (97accordex)
Yeah...just opening the gas cap isn't gonna do much as far as pressure goes. You are gonna have to release the pressure in the line. I'm thinking just being careful when loosening the banjo bolt will do. I'm actually going to do this job some time this week.
Old Jan 29, 2002 | 11:04 AM
New User
Default Re: help with fuel filter... (Phat GS-R)
Wowwww.....I just noticed how old This post is....ignore me....
Old Jan 29, 2002 | 11:28 AM
mercury's Avatar
New User
For my 240SX, the procedure for relieving the fuel pressure was to pull the fuel pump fuse and then start the engine. A few seconds later, the engine will stall. Then you can start your work.
Old Jan 29, 2002 | 12:11 PM
New User
Default Re: help with fuel filter... (mercury)
Seriously??? That doesn't sound safe...
Old Jan 29, 2002 | 01:55 PM
96IntegraLS4DR's Avatar
What's wrong with this method ?
Not flaming you or anything just want to learn.
Old Jan 29, 2002 | 02:29 PM
New User
Default Re: help with fuel filter... (96IntegraLS4DR)
Well, I don't like the idea of running the motor out of fuel...it seems you could possibly hurt some stuff...(detonation, etc.)
It's probably fine, but I'd rather do it the other way.
Old Jan 29, 2002 | 04:11 PM
New User
it would probably be OK to do it that way, but to be honest with you... their's no that much pressure. When I did mine, I just put a rag around the banjo bolt as i loosened it real slow. It leaked the gas on the rag, everything under the hood was cool, and i was good to go. Easy... don't worry about trying to be elaborate.
Old Jan 29, 2002 | 06:16 PM
Rtzx9r's Avatar
GDD 1%
The PROFESSIONAL way is to pull the fuel pump relay, start car, and let it die. Then do the filter. It is safer than opening a loaded filter under pressure so close to the battery. This is an easy job and the stock filter is <$30 from the dealer.
DISCONNECT THE BATTERY AFTER YOU RELIEVE THE FUEL PRESSURE!!!!!!!
This way when you hit the wrench on the pos terminal and the car you do not make a spark!!
Old Jan 29, 2002 | 06:19 PM
New User
Default Re: help with fuel filter... (Rtzx9r)
So that's really how you do it huh? I'm really surprised, but i believe you. I guess I'll try it. Heck, it doesn't matter either way. It will get done no matter how I do it.
Old Jan 29, 2002 | 08:52 PM
GSRaCeRbOI's Avatar
after i did mine.. the car would not start until i cranked it over a few times.. i was thinking i did something wrong.. but i guess the fuel just had to go through the new filter... after that it started right up everytime... i just popped the gas cap and then undid the bolts slowly.. make sure you replace the crush washers w/ the supplied ones too... i used an OEM filter. hell no would i pay $90 for a AEM fuel filter
Old Jan 30, 2002 | 12:07 AM
keys's Avatar
Default Re: help with fuel filter... (B18C-EJ1)
Actually, I would change it more often than every 100,000 miles. Every 30,000 miles would be fine. But at $15.70 each at http://www.ahmotor.com, I change my fuel filter every 15,000 miles. It helps to keep gas mileage and performance in top shape. HTH
ohsnapzafingcu
Nov 24, 2012 10:55 PM
arzelee
Dec 28, 2010 10:45 AM
LuderCriS
Aug 28, 2006 12:44 PM
jdmcivicferio
Jan 14, 2004 04:14 PM
animated_life
Mar 2, 2003 01:45 PM
