Help, doesn't start!!!
Old Aug 29, 2007 | 10:11 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Help, doesn't start!!!
So, I checked my spark plugs, only cylinder 1 has oil all over it on the spark plug...
I got it cleaned off and went off to buy a valve cover gasket and grommits or however you spell it but not in stock, so my car is sittin in the parking lot unattended which sucks...
I get no spark also so it might be my dizzy???
Any suggestions will be appreciated...
It's a 95 LS...
Old Aug 29, 2007 | 10:41 AM
Byaaah!'s Avatar
Default Re: Help, doesn't start!!! (Project95LS-VTEC (G))
Bump sorry I just need to get this done like quick and I wanna know why every spark plug I put in cyl. one gets covered in oil...
Old Aug 29, 2007 | 10:44 AM
Byaaah!'s Avatar
Could it be rings, or just the gasket???
Old Aug 30, 2007 | 04:50 PM
ryc555's Avatar
check your main relay if tis "clicking" when you switch ON, check your fuel pump if it is priming. also check your dizzy if you are getting any spark, pull any wire and have it tap to any steel part of your engine, have your friend crank the engine on cabin, you should getting any spark. if there is no spark prolly your coil. check your igniter also if there is continuity. gl
Old Aug 30, 2007 | 04:55 PM
integraturbo's Avatar
take off the distributor cover off and take a look inside to see if it is wet or anything is broken!
Old Aug 30, 2007 | 04:56 PM
ryc555's Avatar
when you putting back the valve cover do you put some rtv on 4 plug gasket and vc gasket?
bwiissofly
Jun 5, 2013 10:24 PM
DelSlowmo
61
Feb 12, 2009 07:50 PM
blk2mid2sol
Jul 26, 2007 05:40 PM
Cabby89
Aug 28, 2006 08:49 AM
Trinity
13
Sep 4, 2002 06:01 PM
