Help - compression tester stuck
Old Dec 31, 2008 | 08:13 AM
phaiwezzie's Avatar
Default Help - compression tester stuck
My compression tester is seized in one of my spark plug holes what do i do?? When ever i try turning it its turning at a joint or something but not at the actual base this is something so little and stupid to happen and i barely threaded it in
Old Dec 31, 2008 | 08:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Help - compression tester stuck
That's odd, not sure about that. My compression tester doesn't have any type of joint at the fitting on the end of the hose.
Also I changed your thread title to be more descriptive for use with future thread searches. Please remember to make descriptive thread titles when posting.
Old Dec 31, 2008 | 09:31 AM
phaiwezzie's Avatar
Thanks i'll make sure to do that in the future.
Old Jan 3, 2009 | 03:32 AM
gutted's Avatar
did you cross thread it in or does your compression tester screw into different fittings for different thread pitches? if thats the case, put some thread locker on the compression tester, tighten it onto the fitting thats stuck. wait a little for the thread locker to dry then unscrew it out. that method has saved my *** a couple times before
KoRn_vIRuZ
10
Aug 18, 2015 07:51 AM
ef_si
Jul 25, 2013 02:09 PM
ej1 rep
Sep 11, 2008 01:19 PM
gutted
Jul 12, 2006 10:15 AM
