HELP!! Cold engine wont start : Extremely weird problem
Old Aug 28, 2007 | 09:26 AM
gogogomoveit's Avatar
Default HELP!! Cold engine wont start : Extremely weird problem
Hi guys,
My 95 GS-R's engine absolutely will not start after it was sit overnight. There is no cranking sound at all. You can hear clicks when the keys are turned. Fuel pump is going, Battery is fine. I am often left sitting in the car turning the keys, trying to start for 15 minutes, and all in a sudden the car will start up just fine. Once the car has started, you can turn it off and start it again no problem.
The ignition switch has been replaced a year ago, which solved the problem for a while and it comes back again. This only happens to the first start of the day. Starter comes with the car.
Do you think things are seizing up inside the engine, locking up the cranking/ cold start? I need your help! Thanks.
Old Aug 28, 2007 | 09:28 AM
AWD Terror's Avatar
Default Re: HELP!! Cold engine wont start : Extremely weird problem (gogogomoveit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gogogomoveit &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys,
Do you think things are seizing up inside the engine, locking up the cranking/ cold start? I need your help! Thanks. </TD></TR></TABLE>
If things were siezed, they wouldn't un-sieze themselves....AKA would never turn over.
I would check your starter and the wires going to it first.
Old Aug 28, 2007 | 09:55 AM
StockDC2's Avatar
Default Re: HELP!! Cold engine wont start : Extremely weird problem (AWD Terror)
Also make sure that the ground on the starter is not loose.
Old Aug 28, 2007 | 10:15 AM
Boosted_JDM's Avatar
Default Re: HELP!! Cold engine wont start : Extremely weird problem (StockDC2)
Rusted positive teminal on the starter. Had a civic with a B18C1. The clicking noise you hear is the solenoid moving, but theres not enough power to to spin the engine, because the terminal is rusted.
Old Aug 28, 2007 | 10:56 AM
Default Re: HELP!! Cold engine wont start : Extremely weird problem (Boosted_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted_JDM &raquo;</TD></TR><TR><TD CLASS="quote">Rusted positive teminal on the starter. Had a civic with a B18C1. The clicking noise you hear is the solenoid moving, but theres not enough power to to spin the engine, because the terminal is rusted. </TD></TR></TABLE>
I checked out the terminal before, and indeed it is quite rusted. I would pinpoint it as one of the potential causes. Thanks!
JayTypeSH
Nov 23, 2006 01:06 PM
winnerpl
Aug 12, 2006 09:27 PM
RiCE On IcE 2
Nov 30, 2004 12:42 PM
AcidFr33ze
Jul 29, 2004 08:40 PM
