help clean engine and engine bay ... =(
Old Mar 9, 2010 | 06:43 PM
lancerkid06's Avatar
Default help clean engine and engine bay ... =(
aight i really want my engine bay to look more fresh than it does ..i just got the car maybe 2-3 weeks ago and i had to change out the valve cover gasket and spark plug seals because it leaked ... anyways the motor has oil and grease all over it and it is caked on pretty good from the previous owner never cleaning it =( .. anyways i want to know whats the best and easiest way i can clean the motor ... i used some purple industrial strenght cleaner but it didnt work out that great .... so i tried it again and did some scrubbing and whipping worked some what but still pretty nasty ..... so what will be my best beat in getting my engine bay and motor clean????
pic of the bay when i first got it ..
see how dull everything looks and take a look at the block the best you can ands ee all the caked on grease ... mad nasty ... need it gone so please help me out .. thanks ..
how good will a power washer work .. im kind of scared to use it though because of all the wires and electrical stuff .. so idk what to try
Old Mar 9, 2010 | 06:47 PM
Default Re: help clean engine and engine bay ... =(
gonna try to take the heat shields of the header tomorrow to see how nasty it is behind that ... as long as it isnt raining here ...
Old Mar 9, 2010 | 07:06 PM
egsleepercivic's Avatar
if you have already degreased it with engine cleaner you need some CD2 engine detailer
http://www.parts123.com/parts123/yb....0g~Z5Z5Z5GAVQH
gl
Old Mar 9, 2010 | 07:40 PM
NACvicSi's Avatar
Use some oven cleaner. I have used it on a few of my cars and after 10min you can just wash the oil away.
My B16 Del Sol before and after
S Del Sol before and after
Old Mar 9, 2010 | 07:58 PM
what kind of oven cleaner is that? and does it eat at paint or anything
Old Mar 9, 2010 | 08:01 PM
kelsodeez's Avatar
derp resistant
purple power+toothbrush+pressure washer on low setting=amazing results.
Old Mar 9, 2010 | 08:17 PM
NACvicSi's Avatar
Just your regular run of the mill oven cleaner in the aerosol can. I went with lemon scented for that JDM look.
I didn't have any issues with paint coming off. Just leave on 10 min.
Old Mar 9, 2010 | 08:35 PM
dntnedvtec's Avatar
Does it paint your valve cover too? JK
Industrial strength simple green and a pressure washer. Spray, wait 2 min, wash. Repeat. DOn't leave it on, it is corrosive to aluminum.
Old Mar 9, 2010 | 08:40 PM
Spawne32's Avatar
i use simple green and water in a heavy concentrate as indicated on the bottle in a chemical sprayer you can pick up in the outdoors section of home depot or lowes, pressurize the bottle, spray the engine bay down good, let it soak for 10 minutes, rinse and repeat until it comes clean. Then use megs hyper dressing on the hoses and other black rubber under the hood for conditioning.
Old Mar 9, 2010 | 09:31 PM
i dont want to have to get down and scrub the stuff off at the moment i already did that and its gonna take awhile to get this stuff off .. its caked up pretty thick .... i want something i can put on it let it sit then spray off and get most of it off then i will do the dirty work and get in there and start scrubbing away .. so what would be something good for that?
Old Mar 9, 2010 | 09:44 PM
Old Mar 9, 2010 | 10:06 PM
jasoncanseeoh's Avatar
use steel wool.... it'll solve all your problems.
rub hard, and you're done. you'll be happy, I promise.
Old Mar 9, 2010 | 10:13 PM
zeusdb1's Avatar
Steel Wool and Simple Green will do the trick.
Old Mar 10, 2010 | 01:43 AM
NACvicSi's Avatar
Oven cleaner. Have you seen the caked on greasy messes it's designed to clean? I plan on hitting the GSR with some when it gets warmer.
Old Mar 10, 2010 | 06:22 AM
teggyjunkie's Avatar
TRIAL USER
oven cleaner! best stuff around
Old Mar 10, 2010 | 06:25 AM
jdm95's Avatar
To answer your question electrical stuff will be fine just cover up your spark plug holes and put a plastic bag over your distributor and fuse box. Its not always needed but i always like to be on the safe side. The one time i didnt cover my spark plug holes i got water in there and caused a miss fire on one cylinder and had to replace the spark plug.
Other than that pressure wash away and hose that thing down with any of the products people have listed above..... A clean engine is a happy one. Plus if you have any leak issues in the future you will be able to pinpoint their location. Caked on sludge sucks.
Old Mar 10, 2010 | 06:36 AM
Alex M.'s Avatar
I've used WD-40 in the past with very good results. I had that axle grease all over the place and sprayed it down with the WD-40, waited five mins. and it wiped everything clean with no residue. Something to try just in case you don't want to use a pressure washer inside the bay.
Old Mar 10, 2010 | 02:20 PM
aight here are some pics of how far i got on cleanign it after using what i hate .. the purple industrial strength degreaser .. still isnt good enough for me .. i didnt have alot of degreaser left and it started to rain so i couldnt get the chance to take the heat shields off and clean the whole front of the block =( .. but will once its not raining and i get some more product to clean with .. lol .... this si maybe after 1hr of cleaning .. how u think its comming?
BEFORE:::::
AFTER::::::
Old Mar 10, 2010 | 02:31 PM
*96EK*baybay's Avatar
You get usually get all this cleaned at a local garage along with your gas tank (cleaned) for abouut $300...If you dont got the money than some heavy duty hard labor should do it.
Old Mar 10, 2010 | 08:59 PM
not trying to pay anyone to clean it. atleast not yet. i'll clean it as best i can and maybe then it wont cost that much for them to clean the rest .. gonna take heat shields of tomorrow as long as its not raining and clan behind them ... i want my motor to look real clean like the rest of my car
Old Mar 10, 2010 | 09:03 PM
NACvicSi's Avatar
An hour? Man that's some work to only get that amount of stuff off. I'm telling you. $2 can of over cleaner, spray on, let sit 10 min, spray with the pressure washer at the car wash, drink a beer and admire your clean engine.
Old Mar 10, 2010 | 09:04 PM
NACvicSi's Avatar
I have some left I'm pretty sure, I'll hit the new teg up with some tomorrow to show you some before and afters of only spraying it on and washing it off.
Old Mar 10, 2010 | 09:22 PM
aight, is your motor caked on with grease like mine is .. lol ... and yeah it was like 40mins to an hr of work ... i had to scrub everything to make the stuff a little clean .. i washed the inside of the bay first to try to get the dirt and grim off the sides where the struts are bolted and it didnt even get it off until i sprayed degreaser and scrubbed them just to make it look like it does now .... my bay is mad nasty =(
Old Mar 11, 2010 | 02:42 PM
Boricuanology's Avatar
DO NOT USE THE STEEL WOOL ON THE PAINT, IT WILL REMOVE IT OR SCRATCH THE PAINT. Get your self a pack of those hard scrub nilon sponges that you can get a whole pack at the 99cent store.
I will go first and take as much as I can at the carwash with just the plaing water, that way it wont be such a big nasty mess once you start cleaning, Nylon brushes are good for hard to reach areas!! Since the engine and tranny are on the car still I will try to move and remove stove around as much as I can to clean those hard to reach areas, it would have been awsome if the engine and tranny were out but thats not the case.
I have never use oven cleaner but oven cleaner have come a long way now, Easy off comes in fresh lemon scents so it would be easier on your nose. ALWAYS WERE LONG GLOVES AND SAFETY GLASES, you don't want your hands to start iching or some nasty stuff to fall in your eyes.
Be paitience and do it over if you have to, DO NOT LET IT GET DRY, if you are using the purple or the green stuff, they work good but you can't let it seat for too long.
Old Mar 11, 2010 | 04:36 PM
OP, you should just pull your motor and clean that ****.
trepteg
Mar 31, 2008 08:02 AM
jlh22179tx
10
Mar 11, 2007 05:53 PM
GroundZer0
Jul 17, 2003 07:59 PM
kkw103
May 17, 2003 01:45 PM
wessieball
Apr 22, 2002 01:02 PM
