Help!! Car shakes while driving!!!
Old Jul 2, 2008 | 08:58 PM
duffman1278's Avatar
Default Help!! Car shakes while driving!!!
All of a sudden today, my car started shaking pretty violently. It had never done this before, I was driving up hill and it just randomly started shaking like crazy as I was going up. I can rev the engine easily and it doesn't shake at idle.
However after class I noticed that when I had my foot OFF the throttle in 4th and 5th gears, sometimes 3rd, it would shake as if I was depriving it of something. The idle was staying constant with no issues. When I stepped on a throttle just a bit, the shaking would go down and go away but once I let it off again, it started it again. When I drop my car into nuetral and coast it though, nothing happens, it runs smooth and as if nothing happened.
What could be the issue?!!? I really need some help thanks
Old Jul 2, 2008 | 09:29 PM
hotrod99's Avatar
Default Re: Help!! Car shakes while driving!!! (duffman1278)
either your motor mounts are going bad or your alignment is way off
Old Jul 2, 2008 | 09:56 PM
Would there be a way to check the motor mounts? Because visually they looked fine. I guess I could try getting an alignment.
Old Jul 2, 2008 | 11:45 PM
J. Funk's Avatar
If the motor mounts are fine then you need an alignment
Old Jul 3, 2008 | 08:34 AM
Just to check though, how would an alignment issue just randomly come about like this? I mean I was driving, then POOF, it started happening.
Old Jul 3, 2008 | 10:16 AM
Circusraven's Avatar
Default Re: (duffman1278)
Maybe some bolt in your suspension set up came loose. I'd say take it to a shop and have them go over it.
Old Jul 3, 2008 | 10:18 AM
I'm going to check it out first because the tools I have, pretty much but if I can't figure it out after tomorrow I'll have a shop take care of it for me.
Old Jul 3, 2008 | 11:17 AM
dumada9's Avatar
check out your suspension, and if you can look closely at the motor mounts, then if everything checks out try alignment
Old Jul 3, 2008 | 06:49 PM
tegra2G's Avatar
what rpm are you at when this is happening??
Old Jul 3, 2008 | 08:29 PM
Well apparently it seems as though one of my oil rings is bad and so I'm either looking into a rebuild or another engine swap. Would you guys happen to know if it would be cheaper to rebuild my B18B or just buy another B18B used or B16A used. This is apparently whats causing the issue. It can occur at any RPM. If I rebuild the engine I don't want to do anything crazy, just an OEM build. Keep in mind this is my DD.
Modified by duffman1278 at 9:38 PM 7/3/2008
Old Jul 3, 2008 | 08:46 PM
denraweb's Avatar
I would say just buy another long block. Here they can be had for around $500, i think a rebuild will be much more than that...
Old Jul 4, 2008 | 06:27 AM
96lsvtec-t's Avatar
buy a shortblock, and put what you want in it while the motor in your car is still drivable, then when you pull it out, put your new one in..... then you can rebuild your old one if you want.....
SIDreamer
Nov 9, 2011 12:39 PM
shraz
Honda Civic (2006 - 2015)
Jan 13, 2009 10:33 AM
Jxi8s2k
Feb 13, 2006 02:14 PM
sleepyhamsterlx
Dec 4, 2003 07:35 PM
onyx00
Sep 27, 2002 12:39 PM
