help with camber kit...
Old May 11, 2005 | 08:33 PM
NiPBoi's Avatar
Default help with camber kit...
anyone know what camber kit i should get??? for a 91 integ...
Old May 11, 2005 | 08:52 PM
..::91TEG-G2::..'s Avatar
Default Re: help with camber kit... (NiPBoi)
skunk2 or ingalls
Old May 11, 2005 | 08:57 PM
tWixT's Avatar
Default Re: help with camber kit... (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 or ingalls</TD></TR></TABLE>
To add onto this, I am about to lower my car on koni yellows and skunk2 adjustables. The front will be dropped 2+ inches so i heard i will need a camber kit. But looking at the skunk2 camber it says its good for 3 degrees +/- but i also thought that an alignment shop can align 3 degress +/-. Maybe i read wrong about the alingment though? Can anyone help?
Old May 11, 2005 | 09:01 PM
Default Re: help with camber kit... (tWixT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tWixT &raquo;</TD></TR><TR><TD CLASS="quote">
To add onto this, I am about to lower my car on koni yellows and skunk2 adjustables. The front will be dropped 2+ inches so i heard i will need a camber kit. But looking at the skunk2 camber it says its good for 3 degrees +/- but i also thought that an alignment shop can align 3 degress +/-. Maybe i read wrong about the alingment though? Can anyone help?</TD></TR></TABLE>
no it cant. i have a 91 with a 2" drop, they couldnt align me with my stock camper adjustments, i had to buy a kit from progress (cheap-o) that didnt even give me the right degree's, it was 1.5 max.. so i have slight camber, but its still within the limits, but not close to 0.
patrickgsr said that its good to have a bit of negative camper so when you take fast turns, your tires will actually be laying flat on the road than if they were set to 0. but its up to you
Old May 12, 2005 | 05:41 PM
NiPBoi's Avatar
koo thnx....i should post this in the dc5 section but since im here what about for a rsx type s???
Old May 12, 2005 | 07:52 PM
mr.beeks's Avatar
yeap is good for tight turns
but you will have to buy need tires every so often...
mercedes is actually testing this on a prototype...
could take turns so easy...
decode22
Apr 16, 2006 03:26 PM
BoOsTiN Dc2
Suspension & Brakes
Sep 8, 2005 04:49 AM
be.twenty
Apr 1, 2005 12:57 AM
Nocturnal
13
Jan 25, 2004 04:18 PM
gribbs
Nov 19, 2003 07:25 AM
