help on brake conversion
Old Mar 2, 2007 | 02:58 AM
lspecz's Avatar
Default help on brake conversion
i am in the middle of doing a 4x114.3 itr brake conversion for my 95 ls, i can take everything out and put the 4x114.3 set in but i don't know how to remove the brake lines and how to put the brake lines together. anyone got a tip on this?
Old Mar 2, 2007 | 04:50 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: help on brake conversion (lspecz)
First off, which 4x114.3 conversion? Is this the 96 spec JDM conversion? If so, the brakes are the same size as the stock brakes. The front calipers are the same and do not need to be changed.
If you are upgrading to the 282mm rotors, read this thread.
https://honda-tech.com/zerothread?id=734560
If you are not confident performing the work, you should have someone else do it. These are your brakes: a critical safety item. You will need metric line wrenches for the line removal. Download a Helm manual to guide you by searching google for "hondahookup manuals".
The 92-96 Prelude VTEC rotors are the best choice as I outlined in the above thread.
Midnight EG6
May 27, 2011 02:11 AM
95LSDOHC
Dec 1, 2004 11:32 AM
BrotherBrown
Feb 23, 2003 06:51 PM
