Help! Axle keeps breaking
Old May 19, 2008 | 04:21 PM
GeezerGSR's Avatar
Default Help! Axle keeps breaking
Hi I have an 93 integra GSR and it keeps breaking axles. It started when I lost both of them and replaced them both with BAP axles. I drove around fine for about a month all over town and then one night while backing out of my driveway the driver-side axle broke. This time I replaced it with an autozone axle because I heard about their lifetime warranty. drove it across town and it broke again. After that I replaced it and made sure it wasn't rubbing on anything(both times the driver axle broke it was when the wheel was turned almost all the way). After this last replacement I start driving it being careful about how much I turn the wheel(only 30 or 45 degrees) and and it breaks again right down the street.
I've done research and heard about how bad autozone axles are, but I want to see if there is anything else that I should check into before replacing it again. here are some more facts of the situation:
-Car is lowered over 2 inches, almost 3, but has been this entire time.(even before the first break for like 4 months, i'm a new owner of the car)
-passenger axle is completely fine(a BAP axle, not autozone)
-The last two times it broke(autozone axles) they snapped completely in two pieces
-They always break where they plug into that coupler between the transmission and the wheel, the longer one(in between the coupler and the wheel) is breaking.
Is there possibility it has something to do with that coupler or the LSD? I saw some info saying motor mounts could cause this? I think two of mine are bad.
Old May 19, 2008 | 08:55 PM
lmike6453's Avatar
i would say mounts if engine is sagging, but also with the car lowered im sure the axles are sitting at a different angle then they were meant to be
Old May 19, 2008 | 11:18 PM
broke.da's Avatar
Default Re: Help! Axle keeps breaking (GeezerGSR)
i had the same problem lol sad to say i went through like 7 axles on my drivers side.. so hapen to be the driver side mount had broke and i didnt have a front motor mount so the engine was snappin the axle..so basically what the guy above me said..
Old May 21, 2008 | 07:50 AM
Death_to_Thieves's Avatar
are you lowered? Camber kit? What size tires?
Old May 29, 2008 | 05:21 PM
h22_da9's Avatar
Default Re: Help! Axle keeps breaking (JAYSEM Society)
i have this same exact problem but mine seems to be the axle seems short so the boot tensions up
Old May 29, 2008 | 05:29 PM
deftonerider's Avatar
raise the car and see if it still does it
Old May 29, 2008 | 06:43 PM
EK 2 9K's Avatar
Default Re: (deftonerider)
i have had a similar problem.....i have a 93 ls and i am also very low. had bad axles when i bought the car so i replaced them. the car shook under heavy accelerating and mostly in 2nd gear, so i raised the car a little bit and still nothing. so i got them replaced again and i still have the same problem. i havent broken any yet but it sure as hell feels like they are going to snap. i have put probably around 1000-1200 miles on the axles in the car now....for now i am just going to ride these ones out but from the research i have done all 90-93 integras have issues with axles. the only thing that i havnt tried yet and has been recommended to me is oem acura axles.
hope this helps and yes i know they are expensive but it might fix your problem
Dave_Dc2
Sep 23, 2009 11:34 AM
flatblack-h22
Mar 7, 2006 11:57 AM
BigBoulda
Jan 25, 2006 08:13 AM
AaronJ
11
Dec 3, 2003 09:37 AM
d_mina
Nov 27, 2003 12:09 PM
