HELP with audio
Old Dec 25, 2007 | 02:49 PM
s_carey's Avatar
Default HELP with audio
im trying to install a new cd player after mine lost power it just shut off and took the dash clock out with it. now with the new cd player im not getting any power what so ever. if u can help just comment
Old Dec 25, 2007 | 06:13 PM
jhammond_82's Avatar
Reject Papi
Default Re: HELP with audio (s_carey)
fuse? ground wire? wired correctly? maybe https://honda-tech.com/zeroforum/47 will help?
Old Dec 25, 2007 | 07:07 PM
CRJenkins13's Avatar
Remote wire is bad, and / or fuse.
Old Dec 25, 2007 | 07:14 PM
islanderz13's Avatar
I'm 100% sure its a fuse. it is most likely, believe it or not, under the hood. I had the same exact problem with 2 del sols, in both of them i was installing, something went wrong, and I had no power, and no clock. and the fuse is under the hood in them. The stereo and clock are on the same one.
Old Dec 25, 2007 | 07:40 PM
DAneronimo's Avatar
Default Re: HELP with audio (islanderz13)
it should be a 7.5 amp fuse under the hood that says "back up"
Old Dec 26, 2007 | 03:02 AM
northemt88's Avatar
It has to be a fuse/relay
Its not the radio because it took the clock too.
Old Dec 27, 2007 | 01:36 PM
s_carey's Avatar
hey man thanks for the help thats what it was i never would have found that thanks alot
Kenneth.Honda94
Audio / Security / Video
Sep 16, 2014 10:04 AM
boostedefhatch
Jul 10, 2009 12:15 PM
97cl2.2
Jun 30, 2009 07:49 AM
Synthesis
Jun 5, 2004 07:55 PM
crxdriver
Aug 23, 2002 07:11 AM
