HELP ASAP overheating
ok
car.97 integra DC LS
motor.b18c1 fully built to the max
darton sleeves
low comp pistons
2.0 bore
aftermaket rods
new everything
ctr cams
aftermaket valve train (everything)
stock timming
nology wires
ngk plugs
!!!!The problem that i am haveing is that my thermostat will not open i put two (2) brandnew thermostat in it from honda. and the upper hoes get's hot but not the lower one (the one that comes off the thromstat houesing). My radiator fluid boills at points and also in the overflow. The fan does not turn on by its self might me sensor so i hard wired it so it works but still overheats. But if i take out the thermostat and dont run anything then my car run's fine and does not overheat but it runs really cool like really cool. I also seen if the fan would kick on when i pulled the thromstat and it didnt but the car never really got that hot only at a stand still but still didnt get all that hot. I never lost any fluid or burn any i dont think?. The car does not leak and the upper hoes gets hot, and the lower hoes stays cool i bypass the heater core and i also blocked off the (joint tube) it is the little hoes that comes off the head if it matters?
wtf please help me anything would help i really dont want to change the headgasket if its not it i really dont get any bubbles in the fluid more like ummmm.. i dont know but its not bubbles kind of like a pluse?
Modified by kings**t at 5:49 PM 7/17/2008
darton sleeves
low comp pistons
2.0 bore
aftermaket rods
new everything
ctr cams
stock timming
nology wires
ngk plugs
sorry i am so fu*king pissed right now i pressed the wrong button all this money just to see it do this does not make me a happy camper
yes spring to the back and the rubber o-ring has two little thing on the back of it thats sits in the thermostat houseing right and the little hole in the thermostat in to the top in the middle of the two little things like bumps or something like that right?
could be ur fan switch has gone bad, and u might have gotten two bad thermostats, its happened to me before. thats my best guess
good luck man
good luck man
thanks man i dont know i just got one of those burp systems for the radiator that screw on the radiator and it didnt work it just started to spill out of the funnel when it got hot and there where bubbles so i am going to change the headgasket
Let me know what u discover since i am running into the same issue.
Fresh build on this Integra LS
SRP pistons, Aagle rods
Fresh Oil, Water and head gasket
New thermostat
new Fluidyne radiator and Spal Fan
Hondata S300 reports 190F at idle, but when driven for like 10 min it gets to 218F and then shortly the OH engine code kicks in.
We have even taken out the thermostat and it ran cooler, but then it slowly climbs to that 218F again. We checked the dip stick and there is no mixing of fluids.
We are thinking it could be the water pump even though is new? Could this be the culprit, since we are wanting to avoid not having to check the new HG.
New thermostat
2.2accord
May 23, 2010 10:06 PM
SiR HatchAlot
Jul 21, 2003 04:40 AM
