HELP! ABS problem?
Old Aug 29, 2002 | 06:53 AM
Camelflaj's Avatar
Default HELP! ABS problem?
I recently noticed that when I hit the brakes, the pedal keeps going down slowly. If I'm at a red light, the brake pedal slowly hits the floor and the car starts moving a little...What should I do?
Thanks
Old Aug 29, 2002 | 07:26 AM
BSQ's Avatar
BSQ
Default Re: HELP! ABS problem? (Camelflaj)
I would first recommend bleeding/replacing your brake fluid. It sounds like you have air in brake lines.
If bleeding/replacing the brake fluid doesn't solve the problem, you may have a brake master cylinder which is going bad.
Old Aug 29, 2002 | 07:41 AM
Camelflaj's Avatar
Default Re: HELP! ABS problem? (BSQ)
Thanks!
malilaz
Suspension & Brakes
Nov 23, 2013 12:42 AM
H.
Apr 28, 2009 06:01 PM
'95 BA8
May 19, 2007 03:25 PM
dahoopdahup
May 2, 2006 03:29 PM
10K2HVN
Jan 18, 2003 12:09 AM
