help!
Old Apr 6, 2013 | 07:27 PM
Edgar Morales's Avatar
Post help!
new here but not new to the honda scene just stumped
ok so i have a EJ6 with a gsr swap the problem is its running super rich it blows out black smoke n no its not the rings or oil its fuel it can be smelled right away the motor was just rebuilt so i know the botom end is new it has new gaskets all around its running a p30 ecu with a gsr base map it has i/h/e 3in piping aem fuel rail dsm blue top injectors it has an aem fpr i tried to adjust the fuel as well but no luck i have the stock gsr IM as well it started doing this about a month ago since then ive tried everything i can think of it throws a cel but when i chek it with the obd2 scanner nothin ive jumped the ecu as well n it gave me the code for the map sensor i changed that twice n no luck ive changed the tps dizzy is new but changed the cap n rotor just to eliminate that new o2 sensor, injectors are clean car has 91oct from chevron oil is fresh i just dnt know hat it could be anymore
any suggestions????
Old Apr 6, 2013 | 08:22 PM
Blackhalo6's Avatar
Default Re: help!
youve got big injectors and an entire aftermarket fuel system using the stock fuel map. you need to have the map changed
Old Apr 6, 2013 | 08:39 PM
Sparksman's Avatar
Default Re: help!
" just to eliminate that new o2 sensor"? So your not running a O2 senor?
Old Apr 6, 2013 | 08:44 PM
Default Re: help!
Sorry lol I do have an o2 sensor
Old Apr 6, 2013 | 08:46 PM
Default Re: help!
What do u mean by have the map changed? Retune???
Old Apr 6, 2013 | 08:50 PM
Blackhalo6's Avatar
Default Re: help!
yes dsm injectors will flow way more than stock injectors at the same pulse width.
Old Apr 6, 2013 | 08:56 PM
Default Re: help!
So if I just install the stock injectors I should be fine??? Cuz it already had those injectors but if the stock ones will make it work then ill do that till I save up enough for a tune cuz there are no places to tune it here n the closest is about 2 hrs away so it's quite expensive for me
Old Apr 6, 2013 | 10:06 PM
Blackhalo6's Avatar
Default Re: help!
If you have stock injectors try em out.
Old Apr 6, 2013 | 10:21 PM
teggy!'s Avatar
you need to get your fuel trimmed.
Posted from Honda-tech.com App for Android
Edgar Morales
Apr 15, 2013 04:51 PM
yeegsr
Nov 10, 2004 11:04 PM
IVI
Jul 5, 2004 11:48 AM
shadowdawn
Sep 4, 2002 05:46 PM
