Help
Old Dec 30, 2007 | 09:03 PM
northemt88's Avatar
Default Help
I just did a head swap on my car and now it isn't holding an idle and it wants to die and if i let off the gas it dies. It is throwing a 14 but i have checked the iacv and i was wondering if you had any other ideas.
thanks
Old Dec 31, 2007 | 01:20 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Help (northemt88)
Check that the holes in the TB before the throttle plate are drawing air for the idle screw, IACV, and FITV (if equipped). Have you set the timing and base idle?
Old Dec 31, 2007 | 04:00 PM
northemt88's Avatar
Default Re: Help (Dogginator)
no it wont idle my freind told me that since they r biger cams i need to adjust the idle screw and the dizzy
Old Dec 31, 2007 | 04:08 PM
St Jimmy's Avatar
* B A N N E D *
And get it tuned
Old Jan 2, 2008 | 09:33 PM
northemt88's Avatar
it drives but i just drove it home and now it won't start back up, before i turned it off it was able to pass like 1200 rpm, my header and down pipe were hot as hell, (glowing-ish)
nemesiskrp
Mar 28, 2009 07:38 PM
teamXteg
Jun 13, 2008 11:08 PM
DAtegLs
Nov 15, 2007 10:37 AM
matix
Sep 6, 2005 09:10 AM
Doogie Howser
May 31, 2002 10:50 PM
