HELP!!!!
Old May 8, 2006 | 09:40 AM
thielkedelsol's Avatar
Default HELP!!!!
i have a 95 B18c and now im having problems im bauging every time i step on the gas like it wants to DIE and fall on its face. i dont know what the problem is, i thought it was the vtec controller nope! everything is back to stock settings, still wants to not as bad but its still there. i thought it was the plugs, still wants to not as bad bauging getting better but its still there ? what do u gap these plugs at ? other then that i thogut it could be my oil was using royal purple went back to mobil 1 but no idea how that would work, i honestly dont know where this bauging is coming from. no check engine light or nothing. any help please i would really lik it, sorry grammer owns me still.
Old May 8, 2006 | 11:59 AM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Re: HELP!!!! (thielkedelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thielkedelsol &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 B18c and now im having problems im bauging every time i step on the gas like it wants to DIE and fall on its face. i dont know what the problem is, i thought it was the vtec controller nope! everything is back to stock settings, still wants to not as bad but its still there. i thought it was the plugs, still wants to not as bad bauging getting better but its still there ? what do u gap these plugs at ? other then that i thogut it could be my oil was using royal purple went back to mobil 1 but no idea how that would work, i honestly dont know where this bauging is coming from. no check engine light or nothing. any help please i would really lik it, sorry grammer owns me still.</TD></TR></TABLE>
What spark plugs, brand and type?
How old are thiese spark plugs?
Have you checked the condition of your spark plug wires? If so, how old are they?
Have you checked your distributor cap and rotor?
Have you performed a compression test?
When is the last time you performed a tune-up?
Have you replaced your fuel filter or fuel pump lately?
Old May 9, 2006 | 10:19 PM
dc5_integra's Avatar
.043 is the gap. I'd do what this guy says..
Old May 13, 2006 | 04:55 PM
Default Re: HELP!!!! (dc5_integra)
i know how to do the timing but like the h22 right up front how do u set the timing on the b18c so i know its dead on ? cant find to locate it
Old May 13, 2006 | 05:00 PM
grannyshifter's Avatar
pretty sure the gap on the B18C is .041
Old May 14, 2006 | 11:01 AM
Default Re: HELP!!!! (grannyshifter)
any one know how to do the timing on this motor so its dead on
Old May 14, 2006 | 11:07 AM
sik96teg's Avatar
with the use of a timing light theres a mark on the timing belt cover that you line up to the crank pulley(drivers side of motor). Start off with the dizzy in the middle.
Old May 14, 2006 | 04:47 PM
qfast817's Avatar
Default Re: HELP!!!! (sik96teg)
make sure you jump your ecu, the noch inthe middle of the 3 toghter is 16 degrees btdc
Old May 17, 2006 | 11:19 AM
Default Re: HELP!!!! (qfast817)
does any one no the right gap on spark plugs for a b18c
luderollin
Dec 13, 2006 02:54 PM
QuAcK5dC2
Aug 17, 2006 08:11 AM
Ronnie00si
11
Mar 29, 2004 12:36 PM
Yyz
Jun 13, 2003 01:56 PM
