help...
Old Jan 27, 2006 | 01:10 PM
poorman's type-r's Avatar
* B A N N E D *
Default help...
i have a problem with my teg suspension it's acting retarded. everytime i make a left turn it make a metal grinding metal sound. i dont know what wrong with it. i change the tie rod inner and outter and the axles, but it still doing it. any advice on what causing it will help a lot thanks.
Old Jan 27, 2006 | 01:39 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: help... (poorman's type-r)
Is this a quick sound, or does it last for the duration of the turn?
Old Jan 27, 2006 | 02:30 PM
* B A N N E D *
Default Re: help... (Dogginator)
last for the duration of the time
Old Jan 27, 2006 | 02:35 PM
Dogginator's Avatar
Daisy... Daisy...
Check to see if there are any obvoius sign of rubbing. Check the lugs. It could also be a wheel bearing.
Old Jan 27, 2006 | 04:41 PM
* B A N N E D *
no sign of rubbing lugs are tight. i found out that it was the driver side axle was leaking grease from the inner boot (didnt rip, but the boot came loose) and put some grease in it but once and a while you can still hear it when turning, but b4 that i jack the car up in the air and drove it and my pass. front wheel was howling loud up at 40+ miles. is that because of my wheel bearing?
Old Jan 27, 2006 | 05:41 PM
Sam92Teg's Avatar
You can jack up the wheel, grap it at the 6 and 9 position and feel for movement in the bearings, then again at the 12 and 6 position.
If you have both of the front wheels off the ground, you can turn the steering left and then spin the tire to see if you can locate the sound or worn part.
If it isn't your wheel bearing, I would guess it might be your brake dust sheild scraping the rotor on tight left turns.
Old Jan 27, 2006 | 05:50 PM
Uncle Willie's Avatar
Default Re: help... (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">
If it isn't your wheel bearing, I would guess it might be your brake dust sheild scraping the rotor on tight left turns.</TD></TR></TABLE>
Thats what mine did so i bent it back out and away the noise went! Cost nothing to fix.
Old Jan 28, 2006 | 11:25 AM
* B A N N E D *
Default Re: help... (RIP Indian Larry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry &raquo;</TD></TR><TR><TD CLASS="quote">
Thats what mine did so i bent it back out and away the noise went! Cost nothing to fix.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">You can jack up the wheel, grap it at the 6 and 9 position and feel for movement in the bearings, then again at the 12 and 6 position.
nope not the dust shield i know what that does. found out grease was leaking thru my axle boot, but the boot wasn't torn, it somehow broke the seal around the little part of the axle boot and grease was leaking thru it. and yes my wheel bearing on my pass. side is out, i think, can that cause it to rattle when i make a left turn
Modified by poorman's type-r at 3:08 PM 1/28/2006
Old Jan 29, 2006 | 05:55 PM
* B A N N E D *
anyone?
Old Jan 30, 2006 | 04:40 PM
* B A N N E D *
can it be my wheel bear that causing it? the right pass. side wheel bearing is out. it making a metal on metal grinding noise whenever i make a left turn. already change driver tierod (inner and outter) and both axles. still doing it.
Born2Build
11
Mar 29, 2011 05:24 PM
Brewer
Suspension & Brakes
18
Aug 20, 2006 09:19 AM
fe519
May 19, 2003 07:29 PM
misledyouth
Aug 12, 2002 02:42 AM
whatcivic
Jul 24, 2002 09:38 AM
