HELP!
Old Feb 18, 2005 | 12:39 PM
lokooo's Avatar
Default HELP!
ayoo ok listen i have some questions about my gsr first one : i have a 5 spd. soo when i'm changing gears i notice that i have to pull the shift ***. hard . is it the clutch cable or is my clutch messed up ..also everytime i go to turn on my car the batt. is dead is it the alternator.. or ..? see i bought it off this guy and i drove it and he drove it but he sed it never died with himm. is there mayb sum connection also he had alot of strobes i rip them off.. i check my voltage for my batt after i was done recharging and it come up tp 14.80 then it keep droping
Old Feb 18, 2005 | 12:43 PM
CNSK's Avatar
Default Re: HELP! (lokooo)
I did not have a clue on what you just said.....please correct your grammer
Old Feb 18, 2005 | 12:55 PM
RuskeR's Avatar
Default Re: HELP! (CNSK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK &raquo;</TD></TR><TR><TD CLASS="quote">I did not have a clue on what you just said.....please correct your grammer</TD></TR></TABLE>
It's not THAT hard to figure out. It's not in spanish or something..
When you pulled the strobes, did you just remove them, or did you take all the wiring out as well?
I don't know whats going on with your clutch. How hard to you have to push/pull to change gears? Maybe, your low on fluid. I'm not sure.
Old Feb 18, 2005 | 01:01 PM
lokooo's Avatar
Default Re: HELP! (RuskeR)
rusker well i have to pull the *** pretty hard so i can shift also i was just taking this lil light lining around my console and around my door panels i just ripped it off then i cut the rest but i cant seem to find where its getting its power from its not connected to the battery soo.. i'm madd stuck
civdub21
May 11, 2007 12:16 PM
JDMPheens
Apr 19, 2006 02:46 PM
PIC Performance
Mar 26, 2005 02:54 PM
4DRmafia
Jun 10, 2004 06:58 AM
ineedmoney
11
May 31, 2004 10:14 PM
