Help!!!!
Old Dec 23, 2001 | 07:55 PM
Outsider GSR's Avatar
Default Help!!!!
Hey everyone, I need help. I recently threw a cel. I checked and found it to be code 22, which has something to do with VTEC and oil pressure??? Does anyone have any ideas of what may have caused this. The only noticeable problems is that when I get on the highway and I punch it, the car wants to go but it feels like the power comes on and off. Any ideas anyone????? BTW I have a 99 gsr w/ a Greddy EVO exhuast thanks guys.
Old Dec 23, 2001 | 08:02 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Help!!!! (Outsider GSR)
usually caused by weak oil pressure.
3 main causes.....
Oil level low
Oil too thin from use (5k+ miles since last change?)
VTEC gasket screen clogged.
Old Dec 23, 2001 | 08:37 PM
Default Re: Help!!!! (Mista Bone)
Thanx for the response, i got the oil changed 2 weeks ago. Do you have any ideas that would cause the engine to lose the oil. I checked I don't seem to be leaking oil anywhere, so what's the deal????
Old Dec 24, 2001 | 03:03 PM
vteg's Avatar
New User
Did you check the oil level on your dipstick. Maybe they did not put in enough, and you burned off enough to cause a problem.
PS Nice hood ornament
Old Dec 24, 2001 | 03:50 PM
speedymon's Avatar
Did this happen all of a sudden or were you messing around with things in the car?
Old Dec 25, 2001 | 12:00 AM
Default Re: Help!!!! (vteg)
The car was running with alomost no oil in it, so i filled it with about 3 qts of synthetic. It seems to be running better, but the check engine light is still on.
vteg : thanx
Old Dec 25, 2001 | 02:42 AM
01geeser's Avatar
New User
vteg : thanx
ouch!! that is very bad for ur car.
Old Dec 25, 2001 | 07:16 AM
Default Re: Help!!!! (01geeser)
Yeah I know , I gotta figure out what's causing me to burn so much oil....
psi-kik
Apr 15, 2007 09:47 AM
1 Cam Wonder
Dec 14, 2004 12:59 PM
joshalee
Aug 26, 2004 12:04 AM
Anderson
Aug 12, 2002 03:49 PM
