heating problem DA
Old Feb 10, 2007 | 10:13 AM
96 EJ8's Avatar
Default heating problem DA
hey guys, 91 integra B18A1.
when its cold outside the teg doesnt want to heat up properly and the gauge is normal running temp. When i rev it to accelerate or drive its fine and hot but when I get off the gas and come to a complete stop at a redlight almost immediately it gets cold. I have to rev the car to ~1400 rpm to get heat
I have had a new rad installed recently as well as a OEM Honda thermostat and had the coolant flushed. where is this problem coming from because its damn annoying. Is it just because of the cold that htis happens and its normal or is it something that I should be worried about and have it taken to a mechanic to check it out?
thanks in advance
Old Feb 10, 2007 | 10:25 AM
boosted_17's Avatar
Default Re: heating problem DA (integrada9)
have you tried messing with the climate controll.....i dont know if that would be you problem just really and idea because i cant figure out why my heat wont work in my 91 teg
Old Feb 10, 2007 | 10:50 AM
96 EJ8's Avatar
Default Re: heating problem DA (boosted_17)
yeah I was playing around with that and still no luck. I tried both ways the fresh air is on and thats how I have it set up now, and I tried it with the air circulating option and that made my windows fog up after 10mins of driving and it made just a little bit of a difference.
Old Feb 10, 2007 | 12:04 PM
boosted_17's Avatar
i really cant think of anything....have you tried going to g2ic.com i think that someone on there could tell you what is wrong with your heat
Old Feb 10, 2007 | 12:36 PM
96 EJ8's Avatar
I searched and still nothing, i tried local forums and nothing also. oh well winters almost over anyways its prolly just the cold air thats making it like that. thanks tho ill just suck it up and ride out the next month and a bit.
ninjaturtleEG
Jan 15, 2010 11:21 AM
longuyen88
Feb 5, 2007 08:02 AM
the.hamburglar
Dec 29, 2003 08:00 AM
