which headunit installation kit fits best?
Old Apr 13, 2004 | 01:50 PM
Lastgsr's Avatar
Default which headunit installation kit fits best?
the one i have is all janky and hte headunit sticks out... im thinking of getting the panasonic cq-c8300u and i want it to fit right and look nice.
Old Apr 13, 2004 | 01:52 PM
Audi A4's Avatar
Default Re: which headunit installation kit fits best? (Lastgsr)
kenwood fit good imo
Old Apr 13, 2004 | 04:39 PM
Bay_707's Avatar
i got the cq8100u i like it because its 200 dollars cheaper.
Old Apr 13, 2004 | 05:01 PM
IntEGNYC's Avatar
Default Re: (707_Eclipse)
If i understand you correctly, any standard single bin headunit ought to fit in the teg.
I bought a wire harness kit from crutchfield for approximately $12. It basically wires up the headunit to your stock wireharness.
Old Apr 13, 2004 | 05:39 PM
hott-nix's Avatar
Default Re: (IntEGNYC)
if your talking about install kit as in mount kit, then metra makes the best fitting kit
Old Apr 13, 2004 | 05:44 PM
zilverz's Avatar
i have found no kit that actually MOUNTS anything in G3 integra ... your best bet is the standard kit ... flipped upside down .. where the headunit is on the bottom and the abs plastic is above it .. and slide it in ... there is no back mounting hardware
Old Apr 13, 2004 | 06:36 PM
3 plus 1's Avatar
I used metal straps to hold mine in. The headunit is a royal pain in the *** to get in and out, but I've found that with all the hidden metal straps it takes me at least 30mins to get out and I know where to reach.
Old Apr 13, 2004 | 07:54 PM
Creep's Avatar
Default Re: (3 plus 1)
single "din".
Old Apr 13, 2004 | 08:12 PM
cougar10ag's Avatar
my HU had to slide into the faceplate kit.. whihc then snapped into the dash.. so basically all you need is a flathead to pry my HU away from the trim kit and it's gone....
Old Apr 13, 2004 | 09:43 PM
scorched0's Avatar
Default Re: (cougar10ag)
Get the Metra 99-7898 It's the Honda Acura Single DIN install kit. Looks good and seems to fit snugly. Circuit City has them. ALso, you can use the American International HON-K828 kit...essentially the same kit, but the AMI kit might be a little cheaper. Either way you'll get good fitment.
Old Apr 13, 2004 | 09:45 PM
scorched0's Avatar
Default Re: (scorched0)
Also, the Metra Turbo harness number for Honda/Acura Is 80-1720. You'll want one of those and one of the turboharnesses for the brand of stereo you have...really simplifies the install process. Oh, and the new CQ-C9700U is coming out now too, excellent unit. keep in mind though that panasonic's CD Changer technology is pretty dated, so you might want to consider what you're going to do with your system.
Old Apr 13, 2004 | 11:22 PM
xplanetearth420x's Avatar
i got sony fits good
Old Apr 13, 2004 | 11:36 PM
Lastgsr's Avatar
Default Re: (xplanetearth420x)
thanks for all the info...
and hehe, yes i meant the mounting hardware and not the actual headunit
Old Apr 13, 2004 | 11:44 PM
AirWaveGT's Avatar
Default Re: (Lastgsr)
i didnt use one and it fits in fine
phayzeone
Audio / Security / Video
Dec 29, 2006 02:47 PM
darkirony
Jun 22, 2004 07:46 PM
Lastgsr
Apr 20, 2004 07:39 PM
Erik_Pb_Foot
Jul 21, 2002 06:37 PM
