Headlight moist ..!!!!
Old Aug 29, 2004 | 10:21 AM
G-bonic's Avatar
Hijacked
Default Headlight moist ..!!!!
Since its getting cold rite now, summer is over im having moisty headlights on my 96 teggy is there anything i can do to stop having those moist inside my headlights.. lemme kno guys.. any help will appreciate ..Thanxx
89 Teggy LS RIP
93 Mazda MX6 RIP (weak)
96 Teggy LS Yummy Luvin it
Old Aug 29, 2004 | 10:35 AM
DontBlink's Avatar
Default Re: Headlight moist ..!!!! (Stock_LS)
a trick that worked for mine was to park the car in the sunlight and take the bulbs out of the headlight and that will dry up the moisture. a friend of mine and worked at a new car dealership and some cars would have moisture in there headlights from sitting and thats what they did, plus like i said it worked on mine.
Old Aug 29, 2004 | 10:42 AM
G-bonic's Avatar
Hijacked
but mine doesnt do it one or couple times only, its like once a week. .... and i dont think its normal....
Modified by Stock_LS at 12:04 PM 8/29/2004
Old Aug 29, 2004 | 10:49 AM
DontBlink's Avatar
just try it, if it dont work, maybe take the headlights out and reseal them. im just saying the bulb trick worked for me, what do you have to lose
Old Aug 29, 2004 | 11:08 AM
G-bonic's Avatar
Hijacked
Default Re: Headlight moist ..!!!! (DontBlink)
thanx homie.. ill try that later when i get home from work...
Old Aug 29, 2004 | 11:20 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I don't know for sure but I think an opening in the housing somewhere would help to keep moisture buildup to a minimum. I know on my headlights which have Hella bi-xenon projectors in them, there's a hole in the bulb holder in back where the bulb goes in, and you can even see light shining back on the ABS modulator and P/S reservoir, but I have never had any moisture buildup problems.
Old Aug 29, 2004 | 11:32 AM
G-bonic's Avatar
Hijacked
Default Re: Headlight moist ..!!!! (PatrickGSR94)
im thinkin the reason why moist build up coz theres no or not enough air coming in and out.. so when it gets cold and then hot, theres not anough air circulating around them thats when the moist start up..
(prolly ill just drill more holes behind the headlights housing....)
Old Aug 29, 2004 | 11:33 AM
Circuit Star-29's Avatar
Water is getting in through somewhere when your driving at higher speeds. The water gets in but can't get out. Just drill a hole (a SMALL ONE) in the back of that rubber grommet thats over the bulb with a 1/4 inch bit . THe bulb seals in you headlights are getting old. THis happened in my old teg.
Old Aug 29, 2004 | 01:16 PM
daLixz25's Avatar
I get condensation in my front left high beam everytime I wash my car. Any ideas of how to solve the problem?
Old Aug 30, 2004 | 12:33 PM
Default Re: (daLixz25)
Take your headlights out and put a layer of urethane sealant around the old seal.
Old Aug 30, 2004 | 10:05 PM
daLixz25's Avatar
Where can I get the urethane sealant from?
Old Aug 30, 2004 | 10:16 PM
Code Blue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daLixz25 &raquo;</TD></TR><TR><TD CLASS="quote">Where can I get the urethane sealant from?</TD></TR></TABLE>
lowes/home depot/autozone/advanced auto parts/pep boys etc etc
Old Aug 30, 2004 | 10:17 PM
any hardware store. you'll need only a light coating so buy a small bottle, unless other parts of your car leak.
Old Aug 30, 2004 | 11:32 PM
Slain's Avatar
silcon worked wonders for mine
Old Sep 2, 2004 | 08:49 AM
Bense's Avatar
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">silcon worked wonders for mine </TD></TR></TABLE>
silicone worked wonders for your WHAT?!!!??!?
Old Sep 2, 2004 | 03:42 PM
iwannaboostmyteg's Avatar
Default Re: (thebense)
yeah you gotta put a thin layer over the original seal and that should do the trick if not then call the nearest mexican and have them do there mexican engineering on that biatch and if they can't figure it out then bascially your f-ed....
Old Sep 2, 2004 | 03:50 PM
Bense's Avatar
Default Re: (iwannaboostmyteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwannaboostmyteg &raquo;</TD></TR><TR><TD CLASS="quote">yeah you gotta put a thin layer over the original seal and that should do the trick if not then call the nearest mexican and have them do there mexican engineering on that biatch and if they can't figure it out then bascially your f-ed.... </TD></TR></TABLE>
what?
Old Sep 2, 2004 | 03:51 PM
G-bonic's Avatar
Hijacked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebense &raquo;</TD></TR><TR><TD CLASS="quote">
silicone worked wonders for your WHAT?!!!??!? </TD></TR></TABLE>
for his moisty ***** !!! not headlight hehehe
Old Sep 2, 2004 | 10:26 PM
Slain's Avatar
good old ball sweat got the best of me.....doh
of course for the headlight sealant lol
Old Sep 5, 2004 | 01:27 PM
lol in reply to thebense I was just messing about the mexican part but man from working construction those guys think up some crazy ways to get **** to work. Just get some high heat silicon and put a new layer around the existing seal on the headlights.
willnfrank
May 17, 2014 02:20 PM
Buktheng
Nov 23, 2004 09:40 AM
pphan3
Apr 23, 2004 07:56 AM
atisvt99
Sep 16, 2003 12:49 PM
Kellindal
Oct 21, 2002 11:43 AM
