headlight fried the connecter! HELP
Old Oct 2, 2004 | 09:37 PM
philibuster's Avatar
Default headlight fried the connecter! HELP
okay so i've had this problem with my driver's side headlight where it keeps on going out but the bulb's still intact. so today, i figured i'd check it out to see what the problem was. turns out that as i was trying to disconnect the bulb from the connecter, it was harder than it usually is. finally after a firm pull, it came out and the inside of the connecter was charred and melted. the headlight's still works but now when i turn it on, it doesn't turn on at first so i have to wiggle the bulb around a little bit to get it on. sounds like i need to get a new 9006 bulb connecter. question is, do you think an acura dealership would cover it under its warranty? if not, what's the easiest and cheapest way to fix it?
sorry for the long ramble.
Old Oct 2, 2004 | 11:08 PM
Dres's Avatar
Default Re: headlight fried the connecter! HELP (silverblurr)
local autopart stores carry 9006 connectors hope it helps
Accorddrver
Apr 27, 2004 09:41 AM
AzntstyleZ
Jan 30, 2004 11:51 AM
slvrcivic97
Apr 12, 2003 11:23 AM
integra99blue
Jan 15, 2002 06:39 AM
neo1z
Dec 3, 2001 02:17 PM
