Headlight Enclosures
Old Sep 14, 2007 | 04:23 PM
SoTexDC2's Avatar
Default Headlight Enclosures
I have an 01 gsr, and I'm looking into an OEM TSX HID retrofit. I am going to buy a second set of headlights for the project, and the 94-97's are significantly cheaper than 98-01's - obviously. Does anybody know if the clear lenses from 98-01 headlights will fit on the 94-97 enclosure, and accommodate the 98-01 front?
In other words, what part of the headlights are different between the two? The lens, or the whole assembly?
Thanks!
Old Sep 14, 2007 | 04:39 PM
Mfoehrkolb's Avatar
they are different amd upi cant mix them up. on the 94-97 the projector on them are sunken back i think 2 inches. and on the 98+ they are bought out further. the 94-97 housing, w/ the projector in would hit the 98+ headlight front peice or w.e its called. http://www.HIDplanet.com
http://www.hidplanet.com/forum...35318
my thread, for my 94 tegg, that i have covnerted to 98+. pm me if you want some more help. just read my thread tells you best ballast and projectors for out application.
Old Sep 14, 2007 | 04:43 PM
Mfoehrkolb's Avatar
what alot of people do, is buy the halo's and retro those. its cheaper than OEM, and the problem with them is that they arent sealed well. you get leaks and foggy lights. buy if your retrofitting your gonna end up resealing them anyways. but if you wanan spend the xtra 50-75 bucks. get oem, retro those, and then re sell the ones on your car.
vietxdragon
Aug 21, 2008 08:02 PM
8400rpm
Jul 3, 2006 08:39 PM
STDClayton
Sep 16, 2005 10:56 AM
ALF
Jan 13, 2004 10:05 AM
AllB18C406
Feb 22, 2003 11:46 AM
