Headlight Adjustment Question
Old Jan 6, 2003 | 04:45 PM
michaelpr's Avatar
New User
Default Headlight Adjustment Question
1989 Integra LS
This car just doesn't light up the road in front of me so well - and one looks further out that the other.
1) How do I adjust both headlights to get proper alignment?
2) Is there anyway to increase the lumens??
Thanks in advance.
Old Jan 7, 2003 | 07:40 PM
michaelpr's Avatar
New User
Default Re: Headlight Adjustment Question (michaelpr)
Hello?
Old Jan 7, 2003 | 08:40 PM
:jdmshmaydm:'s Avatar
1.) In the 94-01 Integras there's screws in the headlight that allow you to adjust the horizontal and vertical beam pattern of the lights. Double check your own.
2.) The only way to increase lumens would be to either buy some higher wattage bulbs like Piaa's or something. You could also invest in H.I.D. but that's $$.
Old Jan 8, 2003 | 04:49 AM
Ricky Rojales's Avatar
Hello?
No one wants to answer you because it's obvious that you didn't do a search. This same question is asked at least once a week. Things start to sound like a broken record.
Look here:
https://honda-tech.com/zerothread?id=189423
https://honda-tech.com/zerothread?id=189001
https://honda-tech.com/zerothread?id=217814
https://honda-tech.com/zerothread?id=278805
Old Jan 9, 2003 | 07:24 PM
michaelpr's Avatar
New User
Default Re: Headlight Adjustment Question (HT Kleenex)
You are right. I didn't do a search first. The time I will do just that. That you very much for the links.
The best information that I found, although I am not so sure if I understand, is the correct light pattern that should form on a wall in front of the car. I didn't notice this in my Haynes manual, but I will look again.
Old Jan 9, 2003 | 09:50 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
the Integra owners' manual shows the proper headlight adjustment. You can also do a 9005 conversion for the low beam projectors to get a 70% increase in lumens with only a 9-watt increase in current draw.
Old Jan 10, 2003 | 01:36 AM
Default Re: Headlight Adjustment Question (PatrickGSR94)
1989 Integra LS
Old Jan 10, 2003 | 07:20 AM
IC x Prince's Avatar
New User
Default Re: Headlight Adjustment Question (Gatecrasher18AF)
or you can take it to a place that does headlight alignments with the headlight tool. it's 15 bucks, but your headlights will be perfect. especially when changing the hieght of your vehicle. but that's just what I would do.
EFR
Nov 16, 2010 12:07 AM
Stunna MIKE
May 25, 2008 06:13 PM
mcyang87
Jan 6, 2008 04:51 PM
