Are Headgaskets a Problem on B18B?
Old Apr 15, 2006 | 03:25 PM
MechEng's Avatar
Default Are Headgaskets a Problem on B18B?
Are Headgaskets a Problem on B18B? Someone from torontointegras.ca said that its a common problem and they go around 100,000 miles.
http://torontointegras.ca/foru...wning
Old Apr 15, 2006 | 04:49 PM
Sam92Teg's Avatar
Default Re: Are Headgaskets a Problem on B18B? (MechEng)
I have a DA and about a year and a half ago at around 275K miles, I hydro-locked the engine and had to replace a bent rod and worn bearing. I was on the cheap and pulled the head and oil pan and replaced the rod and bearing, but reused the old *** 275K mile head gasket and oil pan gasket. Both have been fine and I have almost 292K miles now.
I don't advise using old headgaskets, I was on the cheap and would have redone it with a new OEM headgasket if it had leaked or not sealed properly. Guess I got lucky for once.
Old Apr 15, 2006 | 11:59 PM
Circuit Star-29's Avatar
Default Re: Are Headgaskets a Problem on B18B? (Sam92Teg)
They're fine gaskets...it won't be a problem unless you do something really stupid like 15 lbs of boost or reuse an original gasket.
Old Apr 16, 2006 | 02:49 AM
no2unenolife's Avatar
been boosted for a year at 9 psi and using the original hg for 1xx,xxx miles
Old Apr 16, 2006 | 02:56 AM
LordAphotic's Avatar
head gaskets like to go bad on abused b series engines. as long as you are careful and never let your car heat up badly because of a radiator or leak in a hose you should be ok for a long while. but they usually last around 100k miles. i would get it changed whenever you change the timming belt. just so your engine last longer. always make sure the head is torqued down correctly or oil will leak.
Old Apr 16, 2006 | 04:41 AM
MechEng's Avatar
Default Re: (LordAphotic)
Good to hear, now all I have to worry about is getting the rounded bolt off my caliper bracket.
Drove her yesterday, and is a lot of fun to drive. Its peppier off the line than my SR-V, and I love the shifter! Midrange to high end the Prelude blows it away though. Its very go-kart like, w/ the Eibachs.
Old Apr 16, 2006 | 10:50 AM
Danziver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MechEng &raquo;</TD></TR><TR><TD CLASS="quote">Are Headgaskets a Problem on B18B? Someone from torontointegras.ca said that its a common problem and they go around 100,000 miles.</TD></TR></TABLE>
They lied.
Old Apr 16, 2006 | 11:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LordAphotic &raquo;</TD></TR><TR><TD CLASS="quote">head gaskets like to go bad on abused b series engines. as long as you are careful and never let your car heat up badly because of a radiator or leak in a hose you should be ok for a long while. but they usually last around 100k miles. i would get it changed whenever you change the timming belt. just so your engine last longer. always make sure the head is torqued down correctly or oil will leak.</TD></TR></TABLE>
WRONG!!!... Do not change the headgasket... Only change the headgasket if it fails.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MechEng &raquo;</TD></TR><TR><TD CLASS="quote"> Its very go-kart like, w/ the Eibachs.</TD></TR></TABLE>
So, its twitchy and unpredictable? Or do you just mean that its much more stable with the springs?
Old Apr 16, 2006 | 11:22 AM
MechEng's Avatar
Default Re: (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">
So, its twitchy and unpredictable? Or do you just mean that its much more stable with the springs? </TD></TR></TABLE>
Its very stable w/ the springs. I did notice the PS is way over-assisted compared to the Lude. Maybe its because I have the AEM pulley on the Lude.
Old Apr 16, 2006 | 04:06 PM
Default Re: (MechEng)
Do you have a camber kit? Did you get an alignment? Too much neg. camber can make it seem like the PS is too powerful...
k20z1ej1
Jul 20, 2017 01:34 PM
lesterruckfort
Sep 14, 2008 07:52 PM
blackccoupe
Aug 25, 2008 08:35 PM
bruthaboost
Jul 29, 2001 06:46 AM
