Header question
Old Dec 29, 2004 | 11:16 PM
GSRerrr's Avatar
Default Header question
hey i was wondering how long it would take to install headers, and also if you can pass smog with it. i have a i/e and was wondering if i should complete that with the whole i/h/e. my big question i guess is will i pass smog? thanks
Old Dec 29, 2004 | 11:20 PM
BlackSage's Avatar
Default Re: Header question (GSRerrr)
it depends on what header you get. Might want to research a cat while you're at it. It took me about 2 hours to install a header the first time I did it. Just take your time. You should complete the system.
Old Dec 30, 2004 | 12:12 AM
Kendall's Avatar
Default Re: Header question (BlackSage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRerrr &raquo;</TD></TR><TR><TD CLASS="quote">hey i was wondering how long it would take to install headers, and also if you can pass smog with it. i have a i/e and was wondering if i should complete that with the whole i/h/e. my big question i guess is will i pass smog? thanks</TD></TR></TABLE>
I can usually get a header installed in about twenty to thirty minutes with hand tools (fifteen with air tools) assuming there are no issues with stuck/broken fasteners or product fitment. Most beginners usually wrap up the project in about 2 hours as BlackSage noted.
Smog legality will first depend upon whether the header is CARB exempt. Most CARB exempt headers by themselves will pass the emissions test will no problems assuming the car is in good working order. The same can be said for intakes and exhausts, and you will naturally feel the greatest benefit from the header if it is complimented with additional airflow modifications.
Old Dec 30, 2004 | 12:45 AM
GSRerrr's Avatar
Default Re: Header question (Kendall)
thanks man if it is carb exempt will that affect the performance of the product??
Old Dec 30, 2004 | 01:03 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRerrr &raquo;</TD></TR><TR><TD CLASS="quote">thanks man if it is carb exempt will that affect the performance of the product??</TD></TR></TABLE>
CARB exemption is a certification and has no effect on the products performance.
katanamast279
Mar 6, 2009 12:26 PM
Imp-tuner
Jul 27, 2007 11:36 AM
aznjay510
Jun 25, 2007 09:29 PM
Hellzcivic
Honda Civic (2006 - 2015)
Aug 5, 2006 09:23 AM
94sohcVTEC
May 25, 2005 02:28 PM
