Header install, Replace Cat Doughnut?
Old May 16, 2005 | 03:00 PM
Racermech's Avatar
Default Header install, Replace Cat Doughnut?
As the topic says do i ned to replace the doughnut that seas the cat to the header? Or can i re-use the old one?? I am replacing the manifold gasket, but not sure about the doughnut
Old May 16, 2005 | 03:18 PM
timmy8151's Avatar
Default Re: Header install, Replace Cat Doughnut? (Racermech)
I replaced the donut gasket but not the gasket at the manifold.
Old May 16, 2005 | 03:44 PM
Racermech's Avatar
Default Re: Header install, Replace Cat Doughnut? (timmy8151)
First off, wow am i fried, i spelled donut wrong......damn it has been a long day.
Everything thing i read said to replace the manifold gasket ($11, not too bad) But nothing was mentioned about the donut. It is a wedge gasket so i cant see it going bad, espically with the spring bolts allways putting closing preasure on it
Old May 16, 2005 | 04:36 PM
Ketone's Avatar
if you are getting a 2.5 inch header, you are going to have to replace it anyway, but it would be a good idea to in general. I never replaced my manifold gasket, but if you want to spend the money it is not going to hurt
lostforawhile
Apr 8, 2013 08:27 AM
coot_er
Sep 15, 2009 06:43 PM
alkoholikwun
Jun 21, 2009 02:56 PM
FunnyVictor86
Aug 6, 2008 08:51 AM
redDAinteg
Jun 29, 2005 02:42 PM
