Header install, nut locked and pulled stud out of the head! Help!
Old Mar 15, 2004 | 08:39 AM
94B18B1Teg's Avatar
Default Header install, nut locked and pulled stud out of the head! Help!
one of the nuts locked and pulled the stud out, threads are fine, seems to screw back in, will everything be fine?
Old Mar 15, 2004 | 08:57 AM
TurboBumblBee's Avatar
Default Re: Header install, nut locked and pulled stud out of the head! Help! (94B18B1Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94B18B1Teg &raquo;</TD></TR><TR><TD CLASS="quote">will everything be fine?
yep
Old Mar 15, 2004 | 09:22 AM
94B18B1Teg's Avatar
Default Re: Header install, nut locked and pulled stud out of the head! Help! (hybrid94Si)
okay, on to another problem, bolts are rounding off, that connect the header collector to the cat...what the hell do I do now?
Old Mar 15, 2004 | 11:00 AM
JimBlake's Avatar
Those long strange flange bolts with the springs, right? I just sawed them off & got new ones.
Actually, I got normal bolts, fender washers, & double-nutted them to the header (A-pipe) flange. But I got them in stainless, & used anti-seize, so I can get them off later.
The nasty ones are at the BACK of the cat, where it attaches to the B-pipe. When those rounded/broke, it was a $&%$ to get them out, because they're pressed into the flange. But then I got hardware-store stainless bolts & nuts...
Autoworks
Acura TL, RL & ZDX
Mar 17, 2007 09:11 PM
lilpastrana
Oct 18, 2006 03:30 PM
AGENT 99
Dec 4, 2004 02:37 PM
CALM_AS_A_BOMB
Jun 17, 2004 06:31 PM
TeGGY_LS
Jun 8, 2004 11:24 AM
