head problem
heres what happen when i was undoing the head bolts all came but one. this it slipped. and the socket just kept spinning on it. can a michine shop cut it out. i sure hope so because i need to get that head off. somebody tell me what to do
It sounds like it stripped out the threads. These are in the block and that's not going to be an easy fix. You said you have all the other ones out, so you should be able to break the seal between the head and block and pull up on the head while turning the stripped head bolt. This should get it out but it won't fix the problem obviously.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zbower7 »</TD></TR><TR><TD CLASS="quote">the head of the bolt is stripped and the socket keeps spinning on the head bolt. it just won't budge. what is the craftsman bolt out stuff will it possible get this head bolt out or will i have to take it to a michine shop</TD></TR></TABLE>
Since your other post is going to take about 5 minutes for one of the mods to delete it I'll post the responce here.
I'd give the bolt out a try. It's only like $20 or something. Then you have a new tool as well.
https://honda-tech.com/zerothread?id=784184 has some info on it as well.
Modified by ThePro at 10:53 AM 3/4/2004
