head light problem
Old Nov 25, 2001 | 07:13 PM
Cramerox's Avatar
Default head light problem
I got a 98 integ, its been raining recently and i noticed some moisture in both head lights on the driver side....how do i fix that? do i have to replace the seals? anyone got any sudgestions?
Old Nov 26, 2001 | 11:02 AM
ndustryalGSR's Avatar
Default Re: head light problem (Cramerox)
This has happened to me before, too.
There is no need to take out the headlights, especially since that is such a big job (have to take off the bumper cover, etc.).
Just take out both bulbs and use a blow dryer (it helps to have one of those small, travel-size dryers) to dry out the inside of the headlight assembly. Since both "chambers" (i.e. high and low beam) are joined, you just stick the blow dryer in front of one of the holes and pretty much leave it there until it's dry inside. The warm air will flow in on the one side and back out the other, carrying the moisture with it.
There are some words of caution, though. If you use too hot of a setting or leave it resting against the plastic/rubber seal for too long, you can melt part of your headlight housing. So, use your own discretion, but it can be done easily with this method.
Good luck with the fix.
Old Nov 27, 2001 | 07:25 AM
dynamite C1's Avatar
Default lix
I agree with cotton, blow drying is temp relief but resealing is better than temp.
Old Nov 27, 2001 | 08:43 AM
STK B16's Avatar
Default Re: lix (dynamite C1)
Yup i go with Cotten too... USed a dryer buddy...
zhou9998
Mar 4, 2018 09:05 PM
k3ntegra
Oct 9, 2009 10:16 AM
redludevtec
Aug 18, 2004 04:58 AM
apexiintegra
May 4, 2003 06:38 PM
BeeResp0nsible
Jan 11, 2003 01:00 PM
