Head bolts???
I'm doing a backyard type r setup, and putting a b16 head on a GSR bottom end that I am building. I am going with ARP head bolts. Which ones should I order? GSR? Or B16?
I am raising the compression to 11.5:1, and putting eagle rods in it, along with new seals/gaskets, and bearings. Everything will be balanced.
Any other ideas?? I appreciate comments/flames/suggestions
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamdLScivic »</TD></TR><TR><TD CLASS="quote">Think of where the bolts are threading into....that should be your answer</TD></TR></TABLE>
And in case you still dont get it.....Headbolts are according to what block you use.
K-Drum
Aug 14, 2004 08:51 PM
