Having some trouble....................
I have a 1990 Teg LS. I just swaped a JDM 1990 B16A. Everything is pretty much in there. The problem I am having is that the car has no power to the inside or anywhere for that matter. Also I need a wiring diagram. Some help ful info would be greatly appreciated. I need my car running tommorrow for work.
Thanks for the space.
Yeah my battery is hooked up. No offense taken. I am missing a few fuses in side but not really critical. All the fuses under the hood are there.
cool...just checking. Because when i pulled my motor i popped the big (70A?, i think) battery fuse under the hood. Physically looking at the fuse you couldn't tell it was bad. But after replacing it, all was good.
Really. Well I'll replace it and see what happens. What came to mind was the fact that there is a ground not connected. The ground that was from the battery was hooked up to the old motor. I did the same with the new motor and nothing.
honda9946
Feb 28, 2018 02:27 AM
