Having some problems launchin
Old Nov 23, 2006 | 03:56 PM
MujetDereh's Avatar
Default Having some problems launchin
Hi guys I took my 2000 Integra LS to the track last night and I was having some trouble launchin, I dont have too much power currently and the tires are spinning for some reason. I think its because of my master cylinder, it is Omni Power the reduced clutch, my clutch travel is literally about 2.5 inches, maybe less thats how much there is to push down.
Here is a complete list of all my current mods:
AEM Short Ram Intake
Skunk 2 Intake man/70 mm throttle body + OBX throttle body spacer
Unorthodox Lightweight pulley set
Greddy Headers
Greddy catback Evo2
Random Tech hi flow cat
B&M Short Throw shifter
Omni Power Master Cylinder
Exedy Stage 1 Clutch
Fidanza 7.5 lb flywheel
GSR Tranny
B18B1 block
In a few weeks my head and engine will be at the machine shop, I will be adding the following:
Wiseco 81 MM low comp pistons
Golden Eagle Rods
Crower Stage 2 camshafts
Crower Valve Springs+Retainers
Ferrea Valves
Port n polished LS head
Darton Sleeves
Hondata with boost option
After the engine work is complete I will be putting a T3/T4 turbo kit.
So if you guys can help me currently as to why I am running so bad (17.5+ in 1/4 mile) launchin problems please help
Also if you can estimate how well I will run after all my mods are installed (of course I will have drag slicks by then) please let me know that too, thanks
Old Nov 23, 2006 | 03:58 PM
spikehairboy's Avatar
you will have even more problems with traction after the turbo i suggest putting in stiffer mounts or even inserts also getting a traction bar.
Old Nov 23, 2006 | 04:33 PM
doood's Avatar
been there done that
Default Re: Having some problems launchin (MujetDereh)
how high are you launching? are you dumping the clutch or slipping it? what tires and at what psi do you have them at?
Old Nov 23, 2006 | 04:42 PM
MujetDereh's Avatar
Im launchin it at around 3000-4000 i even tried 2500-2750 and still its not perfect. I also have custom mounts that are really strong and a ingalls torque damper. I am dumping the clutch, the tires are kumho with 17 inch rims maybe thats the problem? They are at about 35 psi.
Old Nov 23, 2006 | 04:46 PM
MujetDereh's Avatar
What traction bar do you suggest that actually sounds like a really good idea, can you please link me the best one in your opinion that is race proven? Thanks
Old Nov 23, 2006 | 04:49 PM
doood's Avatar
Default Re: (MujetDereh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MujetDereh &raquo;</TD></TR><TR><TD CLASS="quote">Im launchin it at around 3000-4000 i even tried 2500-2750 and still its not perfect. I also have custom mounts that are really strong and a ingalls torque damper. I am dumping the clutch, the tires are kumho with 17 inch rims maybe thats the problem? They are at about 35 psi. </TD></TR></TABLE>try smaller rims and stickier tires. also try slipping the clutch instead of dumping it. practice makes perfect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MujetDereh &raquo;</TD></TR><TR><TD CLASS="quote">What traction bar do you suggest that actually sounds like a really good idea, can you please link me the best one in your opinion that is race proven? Thanks</TD></TR></TABLE>
http://www.full-race.com
Old Nov 23, 2006 | 04:52 PM
Fat Chick Magnet's Avatar
http://www.innovativemounts.com
i have trouble launching my car also thats why im only good through the mountains
Old Nov 23, 2006 | 05:09 PM
kuja's Avatar
Default Re: (dc2rtek)
hehe yea, wait till u get the turbo.. u'll be like damn why was i complaining?
Wierd that ur spinning so much, my gsr without the turbo , i could slip it @ like 6k and get a hardcore launch. Now, not so much, i'd have to launch in 3rd.
At least ur not running 18's with ur turbo, then that would suck ;D my 1st turbo'd run i ran a 15, that was kinda embarassing. Deff try diff ways of launching, maybe it is the omni thats making it a little hard for you to slip it. Try to back off the throttle a bit, u'll get it eventually.. I got my et down to 13 @ 120, shitty dunlops, and stock mounts.
Old Nov 23, 2006 | 05:20 PM
MujetDereh's Avatar
Ok I just placed an order on the Full Race traction bar @ 367 bucks shipped... I also have Tien Springs with Tokico shocks. If possible can you guys PLEASE link me a rim + tire package that will give me the best grip on the road that is street legal? I will get drag slicks later but for now I really want nice lightweight rims (16 lbs or less each) for driving on the street I will get 2 drag slicks later. So if you can PLEASE link me a set of 4 rims and REALLY good tires that will give better performance link me. It will be better if it is a lightweight rim + tire package. Thanks!!!
Old Nov 23, 2006 | 05:30 PM
doood's Avatar
for rims i like the ssr type c in 15x6 from http://www.tirerack.com . they only weigh 8.8lbs each. paired with bfg drag radials up front, you wont have any problems hooking up.
Old Nov 23, 2006 | 05:42 PM
MujetDereh's Avatar
dude thats 300 dollars each...
Old Nov 23, 2006 | 05:46 PM
doood's Avatar
haha i didnt even really look at the price. whoops.
Old Nov 23, 2006 | 06:23 PM
MujetDereh's Avatar
If anyone has used lightweight rims+tires package that they can sell or has a link to a good combo or seperate (doesnt matter as long as they both fit toghter) please let me know by linkin or sayin they have used ones or ones they dont used.
Old Nov 24, 2006 | 07:49 AM
7andaswitchblade's Avatar
I really think you should work on your times some more before you go out buying even more stuff. You have a good amount done and to run a 17.5, that's rough. I ran a 16.7 in my bone stock LS with **** tires, I wasn't even really launching it at all, just basically pulling out normal then hitting the gas hard. and even my 16.7 isn't a good time.
Old Nov 24, 2006 | 08:18 AM
aaronISthrowed's Avatar
Default Re: (7andaswitchblade)
Get a traction bar and pratice.
MujetDereh
Nov 17, 2006 10:45 PM
nah22accord
Jul 8, 2005 01:29 PM
Nyteryder
May 11, 2004 09:03 PM
98civicguy
Apr 23, 2003 07:25 PM
vtec69
May 1, 2002 10:11 AM
