HASPORT hydro to cable problems
Old Jul 16, 2005 | 06:22 PM
sohcnotec's Avatar
Default HASPORT hydro to cable problems
Installed a YS1 cable tranny/b17 in my 94 Teg. Using the Hasport conversion kit for the tranny but I can seem to bleed the air out of the system! The pedal WILL NOT COME BACK UP no matter how long I bleed it. I know you have to bleed the line and NOT from the bleeder. But no luck. What the hell do I do now? The slave cyl was fine b4 the swap.
The lever will only move ~.5"
TIA
Old Jul 16, 2005 | 08:00 PM
stareatsun's Avatar
im not farmillier with the kit, but you bleed the clutch from the slave cylender, at the bleeding nozzle. pump thr system up first while its closed, and then open it a little, and push the pedlle in to get all the air out.
Old Jul 17, 2005 | 09:31 AM
sohcnotec's Avatar
Default Re: (stareatsun)
Actually yo can't bleed it from the bleeder cuz it now faces down. So the air will come to the top. So I guess that's why you bleed it from the slave cyl inlet line. But I'm having no luck bleding it either way. Some one must have this kit on their car??
dnxracer
Sep 18, 2017 08:31 PM
my crx
Oct 7, 2007 12:22 PM
ekVtecPower
Apr 16, 2006 05:53 PM
wilntegra
Jan 26, 2005 06:04 PM
som3on3_10
11
Dec 25, 2004 12:47 PM
