has anyone?
has anyone with a DA swapped out their powersteering rack and pinion for one with out powersteering? if so what rack did you use? and did you have to modify anything?
I requested a short story for a title.
can i ask why you would not just take off the belt if you do not want power steering?
but im not sure if any racks would work, maybe an ef rack?
anyone?
anyone?
i already removed the pump the powersteering cooler and the resivoir. instead of putting a little clutch resivoir in its place i want it to look all clean like factory if i could. do you know if any DA integras came factory w/o powersteering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stocker2shocker91 »</TD></TR><TR><TD CLASS="quote">can i ask why you would not just take off the belt if you do not want power steering?</TD></TR></TABLE>
I'm not sure what the circumstances are but if you run a power steering rack without the pump running, it will eventually damage the rack. Op, is that why you want to change it out?
i want to know if there are any DA integras that came from the factory w/o powersteering like in the cx hatchbacks. because mine is leaking and i have the motor pulled so now would be a good time to do it with the most room.
Jon Petersen
Sep 13, 2018 08:07 PM
one slow eg5
10
Sep 25, 2004 01:12 PM
