Harness conversion
Old Jun 29, 2004 | 06:42 PM
Dee A Nine's Avatar
Default Harness conversion
Yo tengo 94 Integ engine... 91 Stock E.C.U.... Question is, is converting the 91 harnesses from the 91 easy to swap with the 94? ****, I heard that process is hard. ;\ Fill me in on details please? I plan on putting back a 91 integ engine if I don't get any ideas sometime soon.
Old Jul 3, 2004 | 03:03 PM
Dee A Nine's Avatar
Default Re: Harness conversion (Dee A Nine)
none?? ;[
Old Jul 3, 2004 | 03:09 PM
3.504's Avatar
what are you doing?
Old Jul 4, 2004 | 08:44 AM
Integra 2.2t's Avatar
you can do it with lots of wiring
Old Jul 13, 2004 | 09:40 AM
Dee A Nine's Avatar
Default Re: Harness conversion (Integra 2.2t)
yeah i know there's lots of wiring involved... but isn't there certain steps to follow? i can't find it on the instruction manual on that Haynes thing... ;\... help needed plzz!! i don't think that my engine swap is worth anything if i don't get the computer to work with it!
Old Jul 13, 2004 | 12:09 PM
iH8RICERZ's Avatar
what kind of 94 integra motor are you dropping in? gsr or ls? that will determine which ecu you can use. if your dropping in a 94 ls motor, then you can run your obd 0 91 ls ecu perfectly fine. If your running a 94 gsr motor, then converting to obd 1 isnt all that difficult. pm blown90hatch He carries the obd 0-1 conversion harness and he can help you out if you want to hook up vtec and convert to obd 1
Old Jul 13, 2004 | 03:23 PM
3.504's Avatar
Default Re: Harness conversion (iH8RICERZ)
you run your ecu, your harness.... use obd1 injector pig tails and the obd0 distributor, or swap the distributor plugs on your harness to obd1. and thats it. if you want to run a vtec motor, wire knock sensor, oil pressure switch, and vtec solenoid outside the harness and run an obd0 ecu... that'd be the cheapest/easiest way. the correct way would be a conversion harness obd0-obd1, then a gsr computer.
Old Jul 16, 2004 | 06:52 PM
Dee A Nine's Avatar
i`m dropping a 94 jdm ls block
abusedvtec
Mar 27, 2008 05:51 PM
Vtak DOHCTA
Dec 20, 2005 08:06 AM
fireisfun
Apr 11, 2005 09:38 PM
ITR.#1446
Dec 31, 2004 12:08 PM
fmfkid250
Jan 25, 2004 08:15 PM
