Hard startup when warm ? NEED HELP
Old May 27, 2004 | 12:43 PM
Seven Deuce's Avatar
Default Hard startup when warm ? NEED HELP
hey guys having problem with my 1990 integra GS. When i start the car after a 5-10 min. while the engine is still warm, it revs up then drops right down to almost stalling but doesn't. rpm goes back to normal. sometimes when i take off after that happened it lacks of power for a few seconds, then is fine again. I got new plugs, wires, distributor, and fuel pressure is good. Anyone got any suggestions on what to check?
Old May 27, 2004 | 12:56 PM
Chris's Avatar
Default Re: Hard startup when warm ? NEED HELP (Seven Deuce)
I think there was a thread somewhere here about a relay going bad related to heat?
Old May 28, 2004 | 12:16 PM
Default Re: Hard startup when warm ? NEED HELP (Chris)
which sections is that thread in ?
Old Jun 2, 2004 | 11:00 AM
Chris's Avatar
either here in integra or Type R.. methinks here
Old Jun 2, 2004 | 11:04 AM
Stewie's Avatar
sounds like a IACV problem to me. How is your cold start? Perfectly fine?
Old Jun 2, 2004 | 03:09 PM
Default Re: Hard startup when warm ? NEED HELP (Family Guy)
yup cold start up is perfectly fine
Old Jun 2, 2004 | 03:27 PM
PLAGUED_DB7's Avatar
main relay homie...happend to my 91 civic hb...change out the main relay or have it cleaned up cause the contact have warped. they can be re-soderd..... good luck
Old Jun 2, 2004 | 03:40 PM
Keno20's Avatar
Yup, definitly main relay to fuel pump, get the contacts resoldered and you'll be sweet.
Old Jun 2, 2004 | 05:36 PM
Tony R's Avatar
Hey here is my thread on that problem I hope this help's, It help me out a lot read through it:
https://honda-tech.com/zerothread?id=868099
Old Jun 7, 2004 | 02:04 PM
thanks for all the help guys got a new relay and problem is gone
Old Jun 14, 2004 | 05:48 PM
Hey guys problem is back it only fixed it for a couple of days. I installed a new relay and it still does it. Any other things i should replace or check?
JasonST
15
Mar 10, 2022 08:46 PM
TheToaster
Oct 18, 2012 07:41 AM
EF9_RIDER37
20
Jun 8, 2010 11:29 AM
ZedEx
Jul 1, 2005 01:41 PM
Michalob234
Dec 29, 2003 06:10 PM
