half sized rad ?
i am going to put in a half sized radiator in my dc i have found two diffrent ones, i asked around and both work well but one is slightly bigger and both are the same price
so my question is which would you choose
http://www.rcautoworks.com/ind...60f5b
http://cgi.ebay.com/ebaymotors...ZWDVW
please no "do what you want"or"thats up to you"
thanks
thanks
I've used the 1st one in my car since i swapped my motor. Its worked well.
My friend did the K swap into his DC2 and used a rad similar to the 2nd one.
I haven't heard about any problems with either. However I have a fear about items too cheap on Ebay.
I would probably go with the 1st one.
i'd stick wit a koyo or fluidyne half size... friend pu an ebay radiator on his car lasted 2 months then i cracked and started leaking...not made very well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">i put a stock Civic SI half length radiator in my DC and it works nicely...its a cheap alternative to the aluminum ones</TD></TR></TABLE>
did the same when i had turbo
Well sell aluminum ones as well, and our service can't be beat. You can read all the good reviews in our thread.
https://honda-tech.com/zero...ge=10
