h22 in integra??
Makes the da really nose heavy and is a very tight fit. check out http://www.g2ic.com. For the same money you could ls vtec.
actually it's not much at all...heavier that is.
There is only like a 20lbs or 40lbs difference or something like that...(maybe I'm wrong), but if you do an H2B, it will bolt in just like a b-series...
if you do an h22 with the h22 tranny, you need to do a pretty good amount of fabrication. It's the same as putting h22's in EF chassis. You need to custom fab the bracket for the mount (tranny side), and you also need to do something about the shifter, since h22 trannys use cables, and b-series use linkage...
