H&R spring problem
Old Mar 12, 2006 | 04:30 PM
IntegraJCEN's Avatar
Default H&R spring problem
Ok the question is are the H&R Sport springs for the 94-01 integra the exact same as the 92-00 civic springs? Because you would think when buying from an ebay power seller with 100% positive feedback over 4000 you would get the right springs. The first set they sent me was for a G2 teg and now they sent me the Civic product number springs but i called and they said even though H&R puts different part numbers on the integra and civic springs they are exactly the same drop and spring rate. Which i don't really believe. I put them on tonight and they drop looks good but i was expecting a stiffer ride. I will call H&R directly tomorrow to ask. I have a 95 LS.
Old Mar 12, 2006 | 04:33 PM
gsle3per03's Avatar
Default Re: H&R spring problem (IntegraJCEN)
spring rate might vary.. since the civic is a lighter car, the springs must be at a lower spring rate. the integra spring rate should be 276f/276r
Old Mar 13, 2006 | 08:17 AM
i just found an old post in the eg civic forum that says the rates are 276 f/r which are the same rates for the integra so maybe they are equivalent springs? Calling H&R when i get out of class.
Old Mar 13, 2006 | 09:34 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I had H&R Sport springs on my Integra and they were a POS... they were not nearly stiff enough for the drop they provided.
Funkin Flux
Suspension & Brakes
10
Oct 30, 2005 03:50 PM
Funkin Flux
Oct 28, 2005 10:47 PM
DIRep972
Mar 13, 2004 05:55 PM
J.A.SBTCC
May 8, 2003 08:04 AM
ALF
Jul 28, 2001 10:22 PM
