Guts in my engine
I bought a 91int which I'm restoring. I noticed that all seals including oil pan was new. and I took it to my boys shop where he measured compression which it came 9.2 stock and he measured 10.4. so what do you think, whole engine was rebuild or what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast2bad »</TD></TR><TR><TD CLASS="quote">ha-ha-ha-ha!!!! like I've always said. v-tech is over rated. nice technology. but damn you guys over rate the hell out of it. i have LS, my bro in law has si and i beat him constantly. LS i have just intake & headers exhaust!! he has headers exhaust!! ha-ha-ha!! do some research before speaking to me.....
Modified by 2fast2bad at 6:23 AM 11/1/2003</TD></TR></TABLE>
that's why you pull on a basically stock Civic Si....
your car is lighter, AND more compression and torque
edit -
edit -
Am I missing something? How did he measure compression ratio? Did he remove the head or what? I didn't think you could come up with a compression ratio number by a compression test.
WElll speaking of weight....
A 1997 acura integra ls curb weight is 2,643
and A civic Si 2000 curb weight is 2601 lbs
Soo..... I dont see how an LS is lighter
also.... The LS does have more torque but the SI has a higher compression
Engine Size 1.8 1.6
Number of Cylinders 4 4
Engine Type Gas Gas
Camshaft DOHC DOHC
Compression Ratio 9.2 10.2
Horsepower 140@6300rpm 160@7600rpm
Torque (lbs-ft) 127@5200rpm 111@7000rpm
BOLD LETTERS IS FOR THE LS
Engine Size 1.8 1.6
Engine Type Gas Gas
Camshaft DOHC DOHC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast2bad »</TD></TR><TR><TD CLASS="quote">LS i have just intake & headers exhaust!! he has headers exhaust!!</TD></TR></TABLE>
i just find it interesting that both you and your brother own a v8 honda.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast2bad »</TD></TR><TR><TD CLASS="quote">do some research before speaking to me.....</TD></TR></TABLE>
do some yourself.
do some yourself.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zomart »</TD></TR><TR><TD CLASS="quote">i just find it interesting that both you and your brother own a v8 honda.
nah, i think they got a honda v twin motorcycle engine in their cars.
</TD></TR></TABLE>nah, i think they got a honda v twin motorcycle engine in their cars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast2bad »</TD></TR><TR><TD CLASS="quote">I bought a 91int which I'm restoring. I noticed that all seals including oil pan was new. and I took it to my boys shop where he measured compression which it came 9.2 stock and he measured 10.4. so what do you think, whole engine was rebuild or what?</TD></TR></TABLE>
I think your boy needs to go back and learn how to do some math and learn to do a compression check correctly. Also you probably need to know what an actual "race" looks like.
Another thing it's <FONT SIZE="5">Header</FONT>, not "headers" you don't have a V6-V8 Honda.
Lastly, do not come in here telling people to do their research when you haven't done any yourself. There are people here that will break off in your *** the next time you post some ignorant **** like that. Frankly, I think you are ******* stunna like the rest of them. Go back to Club-si or Superhonda where you belong. Your stupidity serves you well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeprojex »</TD></TR><TR><TD CLASS="quote">WElll speaking of weight....
Engine Size 1.8 1.6
Engine Type Gas Gas
Camshaft DOHC DOHC
BOLD LETTERS IS FOR THE LS </TD></TR></TABLE>
yeah he bought a g2 integra not a G3+ g2's weigh around 2400lbs
make sure to read in more detail next time
Engine Size 1.8 1.6
Engine Type Gas Gas
Camshaft DOHC DOHC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vardoulika »</TD></TR><TR><TD CLASS="quote">
make sure to read in more detail next time </TD></TR></TABLE>
acually g2 are 60-80 lbs heavier that a civic si....so they weight about 2680lbs....
make sure to read in more detail next time </TD></TR></TABLE>acually g2 are 60-80 lbs heavier that a civic si....so they weight about 2680lbs....
g2 are not 2400 pounds
thay are almost the exact same weight as a g3 teg
90 ls teg = 2590
make sure to read in more detail next time </TD></TR></TABLE>g2 are not 2400 pounds
90 ls teg = 2590
well I had mine weighed at the track once and it came to 2409 its an RS though so that might play something in it also all the A/C and all of the P/S have been removed and has a b16 in it so that might play into it but I had heard stock they were still in the 24xx
took to my boys shop he has a gauge that you have to take a spark plug out and srew this gauge in, unplug the ignition and crank away until he says stop. its pretty bad az.
huh? well I'll spell it out a bit better for you a.d.d. people. he has an si 96 civic that is, and I have an LS integra. what I meant is that in his si
has header and cat back exhaust system and I have intake and header cat back exhaust. Do you see or read what I'm talking about now?????? AH! DUH!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast2bad »</TD></TR><TR><TD CLASS="quote">took to my boys shop he has a gauge that you have to take a spark plug out and srew this gauge in, unplug the ignition and crank away until he says stop. its pretty bad az.</TD></TR></TABLE>
that measures compression. it doesnt give you your compression RATIO. thats something different.
nice language d***. that there garauntees how your parents raised you. and d*** you ever heard of a compression gauge? no I guess not!! you could buy one at sears. a.d.d. I hope you're taking some medication for it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast2bad »</TD></TR><TR><TD CLASS="quote">nice language d***. that there garauntees how your parents raised you. and d*** you ever heard of a compression gauge? no I guess not!! you could buy one at sears. a.d.d. I hope you're taking some medication for it</TD></TR></TABLE>
i hope that statement wasnt directed towards me.
using a compression gauge tells you how many psi each cylinder is generating. calculating compression ratio is totaly different. you use total volume to determine compression ratio. the pressure of the cylinder has nothing to do with the compression ratio.
I would have to say you are one ignorant fool.
They never made a 96 civic si, and you don't know what your compression ratio is unless you know your engine's "guts" are comprised of.
You can't put a compression tester in and extrapolate the compression ratio from that regardless of what crazy math from Pluto you use. Maybe you're the one suffering from ADD, Another Dumbass Dreaming
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90Zcrx »</TD></TR><TR><TD CLASS="quote">
You can't put a compression tester in and extrapolate the compression ratio from that regardless of what crazy math from Pluto you use. Maybe you're the one suffering from ADD, Another Dumbass Dreaming</TD></TR></TABLE>
I think you might be wrong. Compression testers give you the dynamic cranking pressure of an engine. If you know the exact cam shaft spects plus displacement, it should be possible to find the CR. I might just have to try.
