Guages
Old Dec 23, 2001 | 03:38 PM
gsr camel's Avatar
Default Guages
Ok I am about to get a nice little guage cluster (4 guages) I was just wondering if anyone could give me some information on the install of these? (they are autometer)
A/F Ratio Guage
Oil Pressure (mechanical)
Vacuum
Volt Meter
Twanks
[Modified by gsr camel, 7:51 PM 12/23/2001]
Old Dec 24, 2001 | 11:24 AM
Erik_Pb_Foot's Avatar
New User
Default Re: Guages (gsr camel)
Is their any advantage in acuracy to getting electrical versus mechanic guages from autometer, or vise-versa?
Old Dec 24, 2001 | 11:51 AM
maxxdout's Avatar
Default Re: Guages (Pb_Foot)
PB foot, question reguarding your cams:
are you running stock ECU? How do you like the results of them? I have a similar set up and i was debating the 602's because i had read that the 604's were not that streetable without alot of dyno work. Your comments are welcome or just hit me an IM.
TIA
Old Dec 24, 2001 | 02:58 PM
M0NEYnH0s's Avatar
Volt is ez. i used a test light to find a fuse that was live only when i had my ignition on. AF i believe you have to run to your ECU.. but im gonna stop here cuz thats as much as i know
Old Dec 24, 2001 | 03:01 PM
Malice's Avatar
New User
electrical is less messy. machanical ones have a reputation of bursting.
[Modified by MaliceGSR, 12:02 AM 12/25/2001]
Comptech98GSR's Avatar
Default Re: Guages (m0neynh0s)
i heard you don't get an accurate reading of A/F unless you replace the O2 sensor with a wideband. SO basically it is a waste of money, unless you get the good ones, by Blitz or others. Maybe i am wrong, but i have read about it in Import Tuner or one of those mags. Good luck
Old Dec 24, 2001 | 03:05 PM
New User
For your a/f you have a 12v, ground, and illumination (depending on model) and then your 4th (other) wire goes to your O2 sensor wire which is easiest to tap at your ECU. I don't know what color it is off the top of my head, but you should be able to find out by looking in your helms manual.... i'm sure 1:10 of the people on here could tell you though. Someone will reply to this post with the correct wire sooner or later.
As for my cams, I have not installed them yet. I am going to put them in as soon as I can get the head ported and polished and my dual valve springs and titanium retainers come in. I can't wait though! I'll post as soon as I get them in. Good luck
Old Dec 24, 2001 | 03:18 PM
maxxdout's Avatar
Default Re: Guages (Teken)
nice to know. Now, how bout someone clearifying weather the wideband O2 sensor is needed in order to get an acurate reading with a/f gauge??
Old Dec 28, 2001 | 04:44 PM
gsr camel's Avatar
Well I bought the a/f guage now I need to know what wire to splice it to. The violet wire is supposed to be spliced to one of the wires running out of my ecu but I dunno wich one it is! My car is obd1 and I dont know what color wire to wire it to. I know on the obd2 cars that it is the white wire but its diff on my car and I am stumped PLEASE HELP!
the.hamburglar
Sep 14, 2007 06:35 PM
k-series
Sep 11, 2006 09:05 AM
Riake
Jan 7, 2005 02:06 PM
madd
Jul 9, 2004 11:42 PM
