GSR speed sensor
Old Apr 12, 2005 | 06:25 PM
DarkDragon's Avatar
Default GSR speed sensor
well me and my dad put a clutch in my girls car which is a 95 GSR, the install went well but the speedo doesnt work now and the sensor is plugged in. When we removed the tranny from the car we unbolted the sensor from the housing so it wouldnt break while we were taking the tranny out. I dont know what the sensor reads off, maybe a rod off the diff. but could we have lost a rod or sumthing or is it a drop in kind of part? its 170 bucks for one from autozone so i dont want to even try the dealer. so im asking does it just bolt right to the housing and reads or is there a conector between the sensor and what it reads from
Old Apr 12, 2005 | 07:07 PM
9hatchman4's Avatar
Default Re: GSR speed sensor (DarkDragon)
I'd check the wiring going to the sensor before you waste your money. Check the connector itself it may be bad. The same thing happened to my car, and all it was was the harness, I just got one from the junkyard, rewired it and it worked like a charm. If that doesn't work, I'd recommend getting an oem speed sensor, they're only like 200 and they're better than those autozone brands.
Old Apr 12, 2005 | 07:17 PM
DarkDragon's Avatar
Default Re: GSR speed sensor (9hatchman4)
well the thing is the speedo worked fine before the install and after the new clutch it doenst. We took the sensor off so im thinking its the sensor, the wiring harness seems fine and the temp gauge works and its tied into the same harness
Old Apr 12, 2005 | 07:50 PM
bg-33p's Avatar
i have the SAME exact problem after installing my clutch too..any help?
Old Apr 13, 2005 | 09:07 AM
DarkDragon's Avatar
Default Re: GSR speed sensor (teggysue)
well i guess im gonna get a sensor from a junkyard since they cant afford to buy a 200 dollar part right now. Are the sensors the same for GSR,LS,RS ect? i know on autozone website it has the same part number for a 95 GSR and a 95 non-GSR
Old Apr 14, 2005 | 03:14 AM
DarkDragon's Avatar
does anyone know if the sensors are the same on all integras or if they differ between the transmissions?
Old Apr 15, 2005 | 11:14 AM
DarkDragon's Avatar
anyone?
Old Apr 22, 2005 | 12:35 PM
DC2 BoZz's Avatar
pm'd
Old Apr 22, 2005 | 01:46 PM
bg-33p's Avatar
Default Re: GSR speed sensor (DC2 BoZz)
can u pm me too plz?
Old Apr 29, 2005 | 04:06 PM
RSXSturbo's Avatar
all b-series motors speed sensors work
Old Oct 21, 2013 | 09:03 PM
EGee Eddie's Avatar
You can even use the one from a single cam. That's wat I'm doing. Good luck
Kris05TSX
Transmission & Drivetrain
11
Jun 25, 2024 10:04 PM
nickmk3
Mar 28, 2010 04:08 PM
95dsfreakjason
Mar 2, 2010 07:16 PM
foreverwefall
Nov 9, 2006 10:16 PM
