GSR Problems after mods
It all started to have problems when I installed the Skunk2 intake manifold. My idle sensor all of a sudden does not work. I made sure that the correct wires were going to the right places. When I do a cold start it will die if i take my foot off the gas. Also, my car now is burning some oil. After installing the intake and a 70mm TB it is 2 10ths slower in a 1/4. Is it because of the burning oil or because it's at the point where it needs tuned? I am almost positive that the piston rings are the reason for the oil burning. I just really need to know why my **** is acting up. Thanks
any other mods than the intake mani and TB? if those are your only mods, they are really unnesecary for a basically stock engine. could be getting too much air. or you could have the Skunk2 TB problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluemax189 »</TD></TR><TR><TD CLASS="quote">any other mods than the intake mani and TB? if those are your only mods, they are really unnesecary for a basically stock engine. could be getting too much air. or you could have the Skunk2 TB problem.</TD></TR></TABLE>
I have crane stage I cams, dc 4-1 header, test pipe, HKS cat-back, and intake. My TB is Spoon 70mm.
QnzEP3
14
Jan 13, 2010 05:35 AM
jdmjeff
Jul 27, 2007 07:31 PM
